after a few reboots and its not settling change the cpu setting....
k thanks to all everything seems to be running good now after the fifth reboot...guess im just impatient lol atleast no reinstall was required
k thanks to all everything seems to be running good now after the fifth reboot...guess im just impatient lol atleast no reinstall was required![]()
So i just flash 0507 and now there is a new one really do i need to change my phone running fine
I'm staying on 729 honestly. I got only one reboot though, I just didn't feel like pushing it. :]
u cant lol @767 u reboot with with any load added.Hell if could clock at 900 i would do it im crazy i know
might have had a bad flash but which metro off did you flash...try this one MetrOFF-v1.3-MMS-GB-Edify-CM_ASOP-No_Roaming_indicator_Off_signed.zip it can be flash with 3.0.2.8 theres no need to downgrade to 2xxxxx to flash metro off.
i agree with that 100%all should stay at 729 for a couples day to let the phone settle and try higher once the phone seems to be working good...
su
chmod 777 /sdcard
Ok well after a few reboots of the latest build all seems smooth, I did run at full throttle but I am going toscale back to 729 mhz for a few days to see how it goes. I am however wondering when I did the flash I didnt do any wipes just flashed the latest build.... I believe Isaac may havesaid this is ok as it is just an update. Am I accurate in doing so?
Also when I use the videocamera it is making 3 copies of the same vid, is anyone else having this issue?
I'm getting one video showing up. I had a reboot on the 748, I was downloading all of the Google Apps at one time though. So I think it was just me overdoing it. :3Ok well after a few reboots of the latest build all seems smooth, I did run at full throttle but I am going toscale back to 729 mhz for a few days to see how it goes. I am however wondering when I did the flash I didnt do any wipes just flashed the latest build.... I believe Isaac may havesaid this is ok as it is just an update. Am I accurate in doing so?
I have a fix for SDcard/usb mounting issues. If you're having trouble transferring files and them not showing up or deleting files and they're still on the card, try this:
Go into your apps. Open up the terminal emulator
type in the following commands:
Allow superuser to run.Code:su
(the keyboard might disappear upon doing this. Long-press the menu key to bring it back up)
Now, plug your phone into the comp. Try adding music or pictures and see if they don't show up. The File Manager app is slow to refresh, but eventually it does show the newly added or deleted files. Good luckCode:chmod 777 /sdcard
Please let me know if this works and I'll try to implement it into the ROM. I can confirm this works on WIndows 7 x86_64 and Kubuntu 64-bit
It works! Thx Issac![]()
