What lollipop zip is that?
I will. Before I install, can you tell me it is doing and what I have to backup to back out if it doesn't work??
Does anyone have any ideas on how to get the Bluetooth files from the Kitkat files? This continues to be very very annoying!
Did that zip fix your issue? That is everything else that I removed from the official ota zip except for the bootloader update. I left the new bootloader out because depending on what they(Zte) changed flashing the new bootloader on a device that is rooted with twrp could cause a brick if the new bootloader is completely lockedhttps://www.androidfilehost.com/?fid=24052804347806985
See if that helps
For me I had to uninstall alot of system apps like all the Google apps that j could get from the playstore I unistall those alot of the built in apps too including some live wallpapers then I was able to installs xposedI haven't flashed it yet. I want to confirm what I need to backup and how before I flash it so that I have a path back!
Have you tried uninstall systems apps first.I get an executing updater binary in zip sdcard download, error message , when I flash the xposed zip, and it fails
What's does the error sayI get an executing updater binary in zip sdcard download, error message , when I flash the xposed zip, and it fails
Yes but make sure to uninstall them while you have read and write that way they don't comeback. If you just unistall them when you reboot they will be back there again.Im going to try uninstalling the apps
I'll try it out just flash a s a regular flashAlso seems faster...
Could that be a reason xposed won't install correctly, because I don't have read and write?Yes but make sure to uninstall them while you have read and write that way they don't comeback. If you just unistall them when you reboot they will be back there again.
Well twrp has read and write acess so the problem could be because of the apps try to uninstall them with read and write aceas them try installing xposed that's what work for meCould that be a reason xposed won't install correctly, because I don't have read and write?
Yes correct that's what I'm on to 5.1 and let me know if it work.Okay, I'm understanding a little more since I'm on 5.1 O used the switcher zip, uninstalled some system crap, using system app uninstaller uninstaller, flashed the restore zip, and xposed installed.. Thanks Masterchief, Th30n3, appreciate the help
Where they working find before the updateBluetooth still isn't working right. So frustrated!
If Bluetooth still isn't working then it is a problem with the actual update because Zte is lazy, or it is a compatibility issue with the device you are using. I'm inclined to think that it is the latter because I haven't seen anyone but you mention having problems with Bluetooth.Bluetooth still isn't working right. So frustrated!
