Christopherco
I suspect sitting on this phone would shatter both front and back as they are both glass, and I'm only 160 lbs!!! Lol
Ahh, I have a zmax and the back is plastic. I guess that, and the better camera are why the XMax+ is more expensive. Anyway I won't be keeping big phones in my back pocket anymore. From now on nothing with a screen larger than 4.5" will be going in my back pocket lol. BTW I've finished with the stock rom and I'm just waiting for Android File Host to add the XMax+ to their device list so that I have somewhere to upload it to. Once it is done I will need someone to test it for me.I suspect sitting on this phone would shatter both front and back as they are both glass, and I'm only 160 lbs!!! Lol
best thing about exposed module all you have to do is disable xblast and you are back to normalMy build. prop has been altered extensively with xblast and I never backed it up first like a noob. I'm sure someone has a clean one. By the way, thanks again for all your help.
well i Been having bad luck latley I bought a phone off ebay said it was a a z987 and it was not so i found one on craigslist and phone was a 787 grand x max but had to replace screen to find this out. z987 screen works for the z787 anyways I can give you stock z787 un altered build.prop if that would workCan someone send me the build.prop file for the XMax+? It needs to be unaltered.
Unfortunately I have altered it in other ways also with no back up. My guess is jvillejoe probably has a clean build. prop.
Just had to get a warranty replacement and my new phone can't be rooted with kingroot app because it has a newer firmware version. I have tried about 100 times with no results. Until I can get my PC out of pawn there is no way I can root my phone or finish making the stock ROM I've been working on.So how's everything going Masterchief87?
Try here!ok im a noob, this was my first time ever rooting a phone, i got the phone rooted twrp installed su installed was using xposed framework was able to gain temporary rw access and dump the bloatware then decided to flash a custom rom that was for the zmax cause someone else had done it and said it was 99% compatable. Now to where i really messed up during the advanced wipe i acidently deleted the internal storage...there goes my nandroid backup...i was able to flash blisspop onto the phone and it works minus the camera and a few other things media related ie. netflix etc...and it is a bit glitchy...does anyone have a zip of the stock rom pre or post root that i can flash? any help or suggestions would be greatly apriciated and not in vain. you can email directly @williamrittenberry@gmail.com. thank u to all of you who are more tech savay then myself and all the work u do for us idiots who do dumb stuff by not taking their time.
