You can use apps2sd once rooted without partitioning. And you can partition the sdcard in some recovery menus.
Actually, some of the ROMs have the various 2sd methods built in. Harmonia and aospCM7 are two that I know give you tons of internal storage space.
I believe xionia and cwm recoveries allow the partitioning to be done via recovery, but you should research them to be sure.
You are going through more trouble than you need to. Harmonia ROM has the ability to move everything, it is very lightweight yet fully functional, non of the extras the other ROMs throw in, and you don't need a computer to install any ROM.
I really don't need a computer? I've read a lot of threads on flashing roms and they all seem to talk about hooking the phone up to the computer, moving files back and forth, etc. I'm honestly worried about bricking the phone if I try a rom -I CANNOT afford to replace it. Can you please explain (in simple terms, please) or direct me to somewhere that explains how to install Harmonia w/o a computer? Also, does it move the *entire* app to the sdcard, or just partially like when you use the stock 'move to sd' option? I used TB to move most apps, but it leaves stuff behind. Thank you very much for the help so far!Wow, that sounds too easy to be true! I read the thru some of that thread after your last post, but it all sounded so complicated - thank you for the simple instructions! I only have a few simple questions:
Once I do all that, I use TB to put all my apps & everything back on, right? Or are they all still there?
As it is now, my apps are mostly on my sdcard, I moved them with TB, but it didn't *completely* move them, it left some data in internal storage. Can move the entire application to sd and not leave data behind with Harmonia? If so, how? Do I have to move them back to internal first,then move them back, etc?
Again, thank you *so* much for the help thus far, you've made the process seem alot less scary-I might actually try this tomorrow!
Jerry,
Can you please tell me where I can get aospCM7? I really like the sound of that mod.
Hey JerryScript, maybe you could point out where the spaces are in the commands. It might make it easier for her to get it right the first time. I know for me until I knew where the spaces where in the first commands I attempted,I was about to pull my hair out(you helped in this area on a previous post in the thread "Help" I think it was)There is currently something wrong with the thread, linking to the first page or any page that quotes the op sends you to the websites homepage, so for now, here's the page in the Harmonia thread where the developer announces the latest version:
[ROM]Harmonia 1.3 (Aphrodite + Picasticks) 17June11 - Page 50 - Android Forums
Install Terminal Emulator from the market. Once installed, open it and type su, if the $ sign prompt becomes a # sign on the next line, you are rooted fine.
Download the Xionia Recovery and Harmonia ROM to your phone, then use file manager to find them (they should be in /sdcard/download), copy or move them to the root of your sdcard.
In Terminal Emulator, type the following:
su
mount -o remount,rw -t yaffs2 /system /system
flash_image recovery /sdcard/NAME_OF_XIONIA_RECOVERY.img
reboot recovery
Once you are in the Xionia recovery, make a backup, DO NOT SKIP THIS STEP!
Next, wipe cache and dalvik cache
Next, choose install zip from sdcard, and select the Harmonia ROM's zip file
Next, choose reboot
You should now boot into your new ROM, it will take a while, you system has to rebuild alot of files, so be patient!
If you do have any problems once you flash your new ROM, turn off your phone, hold down the home_key+volume_down_key+power_button till the LG logo goes away, then it will boot into recovery. Choose restore backup, and you will be back to your stock rooted phone.
what am I missing here?
