Root ROOTING For Dummies Guide.....the Gingerbread Edition
Hey folks. Running into an issue here.
I get to step 5 just fine. It runs and I get a menu, where I see 'S-ON' at the top. I select bootloader and recovery. The phone then reboots. It gets to a picture of a phone with a red !
Pulling the battery and restarting it brings it back up.
The window where I ran the tool has:
Beta key accepted - thank you for participating!
Zerging Root... this might take a minute or so.. Root acquired!
Sending in Caroline...
Cleaning up...
Rebooting to fastboot...
When life gives you lemons, don't make lemonade. Make life take the lemons back!
Waiting for fastboot...
Any thoughts?
revolutionary.exe running, accepted beta key, Zergin root... this may take a minute or more..
and nothing has happened for fifteen minutes!!! What should I do?
Cleaning up...
Any thoughts?
you can't get into recovery unless you have s-off. see below.
try running unrevoked again
ok it accepted the beta key and has just been sitting here... it says thanks for participating.. nothing else.. do i have to be in bootloader mode to run this?
1.download cm7 on to you card
2.go into recovery
3.make a nandroid backup
4.wipe dalvik cache, cache, and data
5.select install .zip from sdcard
6.find cm7 and flash it
7.reboot
1st boot will always be the longest so be patient.
uh i hate myself... had cm7 installed and working and my dumb self forgot to add google apps so went back installed gapps and now im stuck in boot loop
try running unrevoked again[/QUOTE]
It's still just sitting there again. Is there anything I should be doing on my phone? And I take it you meant rerun revolutionary.
when i go into hboot it has s-off but it says i have no images for any of the items it lists. do i have to download something?
