did already...go into recovery and wipe dalvik cache and cache
kk i did that and it went to that phone with the triangle and exclamation mark? did i do something wrong?
where did you put the file when yo transfered the file to your card? look for this file name su-2.3.6.3-efgh-signed
did already...
ok Fix... I removed HTC SYNC and now its working... It was stuck on thank you for participating
so, synergy or cm7?
ok. I'm rooted now too.![]()
I was running revolutionary as my user (on linux), but it needed to run as root to get it to do the right thing.![]()
Thanks
disable htc synch if you have it. turn off any anti-virus software on your phone and computer. try that.
How do i disable HTC sync?
Does it come with the Phone?
no it would be on your computer. if you do not have it then no worries.
