if i root my phone do i need to flash a new ROM on to it or can i run my current os and just get root apps off the market??
all of this is installing a rooted rom. so to answer your question without the babble "NO" you cannot preserve the current OS. back up your data and follow the guide if you want root.there is a much easier way of doing this, if you want to root then just follow the instructions in the sticky. it will give you a rooted version of 2.1 so you can get your root apps.
Thanks guys. So it will be easier to just root and flash sensible or vanilla on it
I'm looking to use the whole thing basically I want the pop up on the bottom and most of the widgets
TW,
Your question - as posed - is a little bit odd, but I'll give you an answer which is a little more informative, and (also) without the attitude.
The reason that I say "odd" is that the easiest way of rooting your phone involves overwriting whatever is there to begin with - and that sort of renders your question about preserving the OS moot.
However, there is a way to "root" your phone and maintain your current OS, This means that the answer to your question is "No, you don't need to flash a new rom". (It is slightly more technical than the original (manual) method of gaining root, which is in turn harder than using the PC-based EMA application).
So, the basic answer to your question, though, is "No", and it applies to anyone still on 1.5 or those that have upgraded to the recent OTA-2.1, whether they did it in true OTA fashion, or downloaded the OTA and applied it to the phone as an "update.zip" file.
[SIZE=+2]( This does not apply to any of the Leak versions v1, v2, or v3 - please don't ask. )[/SIZE]
The way this works is a three step process:
1) You replace the bootloader with the S-OFF bootloader using Toastcfh's battery pull method
2) You install Amon_RA's recovery by using fastboot from the PC
3) You make a backup of your current configuration to your SD card with the newly-installed Recovery boot using the "Nandroid Backup" option.
Once you have done this, you are free to either:
- Modify your existing O/S (this requires knowledge of Unix) by adding bits and pieces in order to add "root" to it., or
- Install any one of a number of ROMs, confident in the knowledge that you can restore back to your "factory" O/S (by doing a Nandroid restore from the recovery console) any time you please, if you are not happy with any of the ROMs you try out.
Note that what I have provided here is an outline, not a step-by-step Howto or Tutorial. I am 100% sure it works, having done it multiple times. I have purposely not created a Howto, because you should have an understanding of what is happening at each step before you try it. I will also say that manually adding the correct bits and pieces to your factory O/S in order to get it rooted requires quite a bit of learning on your part if you don't have Unix skills, and in any event, going through all that effort beggars the question, "why not use a ROM where someone has already done this for you?".
eu1
ok cool now i need to find a good ROM with HTC sense still on it anyone know any?
if I root, will it wipe out my sd card or contacts?
