Root Rooting the Boostmobile zte warp 4g lte model N9510
The download is fine..my phone just doesn't want to open it....i believe its because i have the warp 4g and this root if im not mistaken is for the older version...but thanks!
Use es file explorer in Google play store and is in your download folder
my phone was rooted and i saw that there was an update. i let it update and i forgot that it would unroot it. is there any other way than framaroot? both say that theyre not working.
I just bought the Zte Warp n9510. I went right to framaroot and rooted it.. Works like a charm like always. Used framaroot for plenty of phones. about a few hours after my phone started freaking out and freezeing. I havent installed anything else after rooting besides Root checker. When i press the power button to turn the screen on after being in idle i just get a illuminated black screen. sometimes it takes me 10 restartes just to be able to see my screen.
You could install CWM Recovery/PhilZ Recovery and flash a rooted rom.
Hello everyone, it seems the Framaroot link isn't working for this model anymore. It gives me a dropbox logo and says not available. I'd like to root to get rid of bloatware and I guess speed this phone up to get closer to its namesake. Any suggestions? Thx for your time.....
If I read the correctly, you are not able to download the file for Framaroot??
I'm not sure what link you are using? Whoever is hosting the file may no longer be hosting it on dropbox. I think you can search for it on XDA developers site.
Thx for your time. It only had one link for the warp 4g. I've googled and found nothing else. I'll try the XDA site. Again thx for your time...
Awesome, thx bcrichster! This is my first root. I'm a little apprehensive. I hit down load and it said searching for mirrors. Whats that mean?
Eh, I dunno but just give it a moment and the DL link should appear. You may have to run framaroot twice to get full root on some handsets - not a big deal run an app twice for root tho
BCRICHSTER and XMAN95 Thank You two for your help. It took the first time. The phone seemed faster right away. I had Titanium and it was useless until the phone was rooted. I then could free up some ram. Super Cool. Thanks again.
Glad to help, bro
Good morning members, I've got Titanium BU. In apps list for this model theres a plethora of Google stuff. I've seen the suggested list but I use Google (voice to txt.etc.). I don't want to brick my phone by deleting something with an imbedded necessity. Any one here find some of this the hard way that can give me a more concise list for Google deletes? Again thx ahead of time....
http://androidforums.com/boost-mobile-warp-4g-all-things-root/789458-safe-remove-apps.html
This is not working for new update 4.4.2. I even try root master and nothing... Please come with something for the new update
It just says boost warp 4g. Its not Motorola I think.. I just buy 2 days ago and no rooting apk its working for it. :(
Please check the following and let me know what they say. Thanks
1) Settings > About Phone > Model number
2) Settings > About Phone > Android version
n9510. 4.4.2
Well, it seems that you are the only one with this device that has 4.4.2.
Ok, I will help you get rooted if you will help everyone by grabbing the files from your phone before making any changes :) It would be great to have a 4.4.2 stock rom for all the Warp 4G users. Let me know if you are willing to help out.
