Smokey Mc Pot
The XXMG2 is the newest and the latest firmware released to date and logically is the best contender so far...
But is not perfect despite the great biased reviews posted on XDA...
*People that use the MF1 claim that the MF1 is the best...
*People that use the ME7 claim that the ME7 is the best...
*People that use the MG2 claim that the MG2 is the best...
But the question is:
-Did they tried any other firmware before to compare it???
-Did they perform a factory reset after flashing the firmware???
*If the firmware is so good, than why are they using modified scripts and modified kernel and modified firmware on top as well ???
"That don't make any sense to me."
People that update their phones from Ginger Bread to Jelly Bean using the latest firmware's are updating to 624mb ram without the need to flash the MB2/MB4 first.
And nothing else.
But the claims in relation to a better performance if you revert to GB first.
Are completely unfounded and ridiculous. (To say the least) , the performance is the same after you perform a factory (Rom) reset.
If you are running JB already on your phone? all you need to do is flash the JB firmware you want on top of the one you already have and perform a factory reset after.
Samsung will eventually release some JB update to all the other Rom's to stabilize the problematic early releases... (likely in November or December).
I don't like and don't use Custom Rom's and do not support them either.
If you are having trouble with your current stock firmware?
Just visit the "play store" and search for "Andromizer".
Using Andromizer select "one-touch optimization" and select the tweaks that better suit you.
...My advise is select the "Memory(adj,minfree) Tweak" only to start.
After that apply and experiment with the other tweaks as it suit you.
And problem solved.
Smokey
And nothing else.
And problem solved.
Smokey
