Fuzzy13
Extreme Android User
did anyone get apex to install?
Use the link Nuttmeg posted. It works
Use the link Nuttmeg posted. It works![]()
Its downloaded as a zip file. I changed it to apk but no luck
i pull the apex launcher from the jelly bom rom and it works good on the esteem, will upload.
ApexLauncher.apk
ApexLauncher.apk
I'm getting an error on downloading the apex launcher![]()
Alright the Aroma installer is cool as shit.... I am making crap using it for now on...Im just going to pack everything theme, rom, tweak, apk, kernel all in the mofo and it'll be like 9gb but I dont care! Ahaha
Thank fuzz it says app not installed do I need to use root explorer? And move it to system app
I copied it to the system using commander and usually when you do that you dont even have to install it, it installs automatically upon being copied over. No reboot or anything. One of the MANY reason why I love commander.
Yeah try system/app
Make sure its on RW
Nice find so what is in this that #2 doesnt have already integrated?
I just made one of these Aroma installers for stock apps just messing around....easy as hell....Prepare for a crap load of Aroma installers by me![]()
Did Smart Stay work?
Same here![]()
I think it works.. did you turn it on through the app?
