Fuzzy13
Extreme Android User
I still haven't had a chance to try this. Do i join fuzzy and his minions?
Yes
tried it on my phone runniing #2 2.5 not very noticeable difference to me.however did make a very noticeable difference in my wifes stock esteem.but since every phone seems to act a little different it is worth following fuzzy down his path of darkness lol![]()
I tried to install apex launcher and I get not compatible. I'm running number 2 2.5
Is Android commander an actual app or is it a software that you need a computer to use![]()
Software on a PC
Haha thanks fuzz damn I'm slow lol
It's all good homie. If you can give it a try. I couldnt imagine owning an Android phone and not using it. If your an avid PC user that is.
hi fuzzy i just flash #2 from ldrifta on my lg esteem if i use this script
will this change the rom configurations can i revert back?
tank;s alot for your time
it's so easy a,
hay wat up i dont get it i installed pimp my rom but all i wanted was beats audio and the battery consumption and the speeding up part i did nt see beats audio or anything else
I honestly don't understand the hype with beats audio. It's an eq. Just like any other eq. The speaker is going to produce the same tones regardless of what eq is used.
And if it's anything close to beats headphones, then I'd rather be deaf. Worst expensive garbage I've ever laid my ears upon. But most of you know my stance with that![]()
So whats thecsteps to "push" an app into the phone. Like i want to install the sony walk man player. Thats what got me hyped. Hiw do i do this?[/QUOTE
Download it here and push it in system folder http://db.tt/oB3S2BK3
Do i use a pc or can i do it from my phone? I just copy the apk to the system/apps right?
u might have to rebootYou can download from phone and yes copy to systemu might have to reboot
