Root [Script] Pimp My ROM
Silly me, I thought there was a reason we weren't using aroma installer and didn't want to look stupid for asking why. I should have said something a long time ago.
I saved the log (the tweak log i guess?) after i installed the tweaks. How do I install the log w/out having to flash all the tweaks that I flashed before?
How you got it to install some of us haven't yet so nothing special?
Really? Are you using commander? If not I recommend using commander to push it.
It could be like swype. Swype is such a pain in the ass to get installed if youve deleted it.
How I would try to install if I didnt have commander. Copy and paste it to system/app. Obviously make sure system/app is R/W. Reboot. if it doesnt install on boot then navigate to the system/app folder and double click the apk and see if it installs.
EDIT. So I went and tried it manually and just PASTING it to system/app from my sd card installs it. Didn't have to double click it or anything. O_0
^That worked for me too
ICS only my.....Wonder if Nova will too
No go on Nova
I did it on my phone using root browser.I tried moving it from my sd to system app but didnt work. Then i copied and pasted from my sd to system app and it worked O_oThis is a moded apex launcher I believe. It doesn't have current features and when I go to the market it doesn't say its installed. Usually if the app doesn't support gb it would say error paraphrasing package or something like that.
Well yeah it's been ported over. It was not made for GB so technically it's not legit.
Sooo after installing this for a day, I have to say that it does what it says it does from what I applied, connectivity to wifi is faster, and some other things, but the battery drain is horrible, even on idle. Uninstalled. Anyone else experiencing battery drain?
no batt drain noticed. I have been off the charger since 9 this morning, it's now 420 (ha ha, break time lol) and under heavy use I'm down to 70%. I've flashed about 7 different themes, made 2 complete backups and rebooted about 100 times today. Lovely.
Great find Fuzzy!!! Works great on the revo too.
tried it on my phone runniing #2 2.5 not very noticeable difference to me.however did make a very noticeable difference in my wifes stock esteem.but since every phone seems to act a little different it is worth following fuzzy down his path of darkness lol:D
