Root SD card installation aborted
mjmarket
Hi MY rooted EVO 4G is HBOOT 2.10 radio 2.15 using recovery RA-supersonic -v2.3 > when try to change ROMS by flash zip from SDcard it starts> install from sdcard ,finding update ,open update , E:can't open /sdcard/.... ......... (bad) ,installation aborted. I have put My downloaded rom's on 3 different sd cards with the same result. :mad:
Hello and welcome to AF!
I have moved your thread to the all things root section where it will be seen by other rooted users.
What ROM are you trying to flash? It sounds like it may be a bad download.
I am running MIUI 1.12.30 and trying to get the newest GB , none of the ROM's on my SD will flash even if I move them to a different card. Where is a good place to download ROM's?
A lot of the official MIUI builds for the EVO were garbage, so it could just be that the ones hes trying weren't any good or werent made for our device.
If the one I linked fails we know theres a deeper problem
The one I linked is the best MIUI build there is with everything working except for 4G.
The problem may be your 32GB SD card. The EVO doesn't really like cards that are too big or too small. Do you have an 8GB or 16GB card laying around you could try?
