Masterchief87
Android Expert
Go into storage settings and erase SD card. That's all you gotta do.Does anyone know how i can format my sd back to fat32 im trying to get rid of the hack and got aparted but for some reason it doesnt load ?
I am currently running xperion ROM with the hack, however, I noticed the phone is a bit slower than with the previously link2sd method. I reflashed the ROM, formatted the SD card via settings, then partitioned the card via TWRP and flashed the hack. It is nice to see the total internal memory go up though.Yes this is much better than link2sd
i just did that and seems like my sd cad is still partitioned still have 7gb internal.......Actually it looks like thats not doing anything when i erase data everything is still on the sd cardGo into storage settings and erase SD card. That's all you gotta do.
well i have an issue yes again. when i goto cwm recovery and install data copy zip it just freezes at mounting external partition. been 50 minutes and no change
I had same issues before so i ended up using Twrp recovery it works flawless.well i have an issue yes again. when i goto cwm recovery and install data copy zip it just freezes at mounting external partition. been 50 minutes and no change
I tried to do twrp and all i got was the loading screen teamwin. I think it worked the first time i tried it but i was in a rush to get to work and i exited out early by mistake. Ever since then it freezes on the loading screen. I tried to delete it and start again. Doesn't work. Don't know if maybe something is still loaded that needs deleting but when I try it just freezes up when i go to recoveryI had same issues before so i ended up using Twrp recovery it works flawless.![]()
I am not going to claim my hack is better than any other hack/mod. I have no experience with Link2SD. My understanding is that Link2SD links parts (subfolders) of the /data folder to the SD card, while my hack hides the internal /data and uses the SD card in its place.Is this a better alternative to Link2SD? I have been using it for a while, but perhaps this is faster/"more better"?
Did you uninstall/disable the hack first? Android's built-in "erase SD" should repartition/reformat the SD card if it can unmount all partitions on the SD. A partition in use cannot be safely unmounted. The other option is to partition/format in TWRP. Although I'd still recommend doing Android's "erase SD" even after formatting in TWRP because, as I remember, TWRP's partitioner/formatter doesn't do partition alignment.i just did that and seems like my sd cad is still partitioned still have 7gb internal.......Actually it looks like thats not doing anything when i erase data everything is still on the sd card
Have you been able to make a full backup in CWM recovery? How long does that take?well i have an issue yes again. when i goto cwm recovery and install data copy zip it just freezes at mounting external partition. been 50 minutes and no change
The best things you can do is factory reset within the rom settings then try to flash twrp with the twrp.apk... I knw that the las twrp by hroark does not work properly... I knw GM has one that works good after that reformat ur sd with the with the properties sd partion tools from ur pc make sure u make partitions as primary not logical cus it would not work. Like WarrantyVoider said if u use twrp for partition it will noy aligned blocks correctly.I tried to do twrp and all i got was the loading screen teamwin. I think it worked the first time i tried it but i was in a rush to get to work and i exited out early by mistake. Ever since then it freezes on the loading screen. I tried to delete it and start again. Doesn't work. Don't know if maybe something is still loaded that needs deleting but when I try it just freezes up when i go to recovery
ohh so i have to uninstall the hack by flashing the .zip then erase sd card?Did you uninstall/disable the hack first? Android's built-in "erase SD" should repartition/reformat the SD card if it can unmount all partitions on the SD. A partition in use cannot be safely unmounted. The other option is to partition/format in TWRP. Although I'd still recommend doing Android's "erase SD" even after formatting in TWRP because, as I remember, TWRP's partitioner/formatter doesn't do partition alignment.
You are trying to 1) remove the hack and 2) repartition the SD card as one fat32 partition, yes?ohh so i have to uninstall the hack by flashing the .zip then erase sd card?
Oh well. F6 is a good, capable device. 2100 MHz band (for international 3G), LTE, dual-band 802.11, Bluetooth 4.0, etc. All for a reasonable price. But like most if not all technology items, something better will come along.well guys I am unfortunately informing you that I am going to be no long owning a lg f6.
Good luck to you.
Yes I know. I did not misunderstand you. I was not suggesting you replace an F6 with an F6.Hey WV, im not getting a F6, im going to upgrade. but I cant afford top shelf phones. so im on metro pcs and I really don't know what to upgrade to.
My comment just reflects my musing that I like the F6 for what it is and has, but I understand you want something better to suit your needs.Ah sorry, I have been going google crazy looking for a new phone, funny thing. the zenfone 2 just came out in US. the have two versions and im thinking about getting the more less expensive. don't know if its good on the metro pcs network. I have a lot of reading up I gotta do. sheesh. oh does anyone watch The Flash.Yes I know. I did not misunderstand you. I was not suggesting you replace an F6 with an F6.My comment just reflects my musing that I like the F6 for what it is and has, but I understand you want something better to suit your needs.
Hopefully the others can give you some suggestions. Or you may want to try asking in a general forum/thread to get more responses. Good luck.
Go to gsmarena or phonearena sites... Compare...Ah sorry, I have been going google crazy looking for a new phone, funny thing. the zenfone 2 just came out in US. the have two versions and im thinking about getting the more less expensive. don't know if its good on the metro pcs network. I have a lot of reading up I gotta do. sheesh. oh does anyone watch The Flash.
Does -uninstall.zip not work for you? It should undo changes made to the /system folder.I did the procedure but my phone started lagging (since my sd card is not fast enough), is there any way to undo this?, Thanks!
when i go to TWRP to reboot recovery the screen resets to the TEAMWIN start screen then doesnt go anywhere else. any ideas?
I've had a plan to release a zip that would create the additional ext4 partition directly in recovery to help make the process simpler and hopefully less troublesome for new users. Unfortunately, I got sidetracked by other projects before I finished testing. Thanks for reminding me.TWRP freezes while loading if the SD's partitions were created incorrectly.
