-V-O-Y-A-G-E-R-
i haven't done a proper testing, but I'd say that my Pebble do have a lower capacity than stated. It empties very quickly and unexpectedly.
Reporting back with more testing on my Powerbee. This is on my second run, i.e. the first time I completed charged the Bee myself. So far I've had:
Desire: 16% -> 75%.
I didn't want to leave it overnight so stopped at this point.
~850 mAh
Desire: 15% -> 99%.
Again I was going to bed and this was close enough for me.
~1200 mAh
Near the end of this charge the third light turned off, thoguh it came back again and disappeared a few times over the course of ten minutes or so, it must have been on the boundary.
Nintendo DS Lite: 20% -> 100%.
The 20% is an estimate based on the power light turning red at 30% and how long the battery normally lasts after that. This is a 1000 mAh battery.
~800 mAh
I realise batteries aren't generally their stated size in reality but I don't have any way to measure that. My Powerbee should have around 2000 mAh left in it right now, enough for another couple of Desire charges similar to those above. I still see two lights on it so that's a good sign.
Unfortunately I need the Bee to be fully charged for a camping trip this weekend so I'm not going to have a chance to drain it completely to find out if that is the case. But testing will continue over the weekend and next week.
Have people seen this: HTC DESIRE EXTENDED LIFE BATTERY - HTC Desire
It doesn't have specs yet, but might actually have higher capacity as it's bigger - of course you have to use their special back plate as well though, but might be good for when you know you won't be near a charger (i'm thinking festivals etc). Anyone used one like this? Are there other makes of oversized batteries for the desire?
Just received my Veho Pebble and am a little disappointed what it says on the back of it. It says Output 5v 750mA and not 950mA as advertised, even on the Gizoo website.... Can you guys check if yours is the same or not please? Am wondering if they have changed the item....
The box also says 750mA and moddel VCC-A007-PBP on top of the barcode.
edit: the Manual states 950mA Nominal..... Also there are 11 tips with the packaging?
2nd edit: 10 tips, 11th tip is to charge the device...
Nope, I am involved with a Duke of Edinburgh group, had a Silver assessment this weekend in the New Forest.Camping trip? Farnborough Airshow, I presume?
I also bought the 2400mah 'extended life battery' and have found the same as the other guys. probably slightly worse performance than the stock battery. for
