Root set cpu help
frankie51
I have the B.O.S. Kingdom Port R3 rom and I want to install setcpu to increase battery life. I do not want to over clock, just underclock. How do i do this? Do i need to install a custom kernal?
If you just want to underclock, no you do not have to flash a custom kernel. You'll have to disable perflock before you can undercloc a stock kernel, and you can do this through SetCPU.
what settings should i turn the phone to when the screen is off if i want to underclock? and also will this make me recieve text messages late?
Well lol you might get texts late but it won't be related to clocking your kernel :)
You may experience difficulty under clocking on that beastly giant Rom lol. Just saying...
I would recommend NOT using SetCPU for this rom;) Sac's has Collin's battery tweak set up for this rom. You can set up the tweak via Terminal Emulator.
Go into TM
Type
su
Then type
batt-cfg
Press
5 enter
Then
9 enter
to save changes
Then reboot the phone
Go into TM
Type
su
Then type
batt-cfg
Press
5 enter
Then
9 enter
to save changes
what does this do?
