LittleRedDot
I'm using the other one, but it seems to be the preferred recovery amongst you folks. If I were so inclined, and there were specific benefits, please let me know how to make the switch.
I'm a force of habit.While We're on the subject, how do I take screen shots in recovery?
Hey, just wait one minute! CWM recovery works just fine! I used it for over a year, and didn't have too many problems.![]()
You don't flash this like a regular zip file. It needs to be named "PC36IMG.zip" exactly (without the quotes) and on the root of your SD card. This means the top level of your SD card, so not in any folders on your SD card. Load up the bootloader (the white menu you get to while holding vol down and power at the same time). It wills can for the PC36IMG.zip file and when it finds it, hit yes to update. Then select no for rebooting and then you can go back into your new recovery.Tried flashing, got an abort - "can't find updated script"
I'll +1 the new amon-ra style recovery. It just works better, it has a more refined UI, and you don't have to wipe 8000 times per flash. Ok I still wipe 8000 times pet flash, but that's beside the point.I'm a force of habit.
Absolutely switch, you'll never look back.
Wow I didn't even realize that. Since I always back up recovery when I nand backup, I had reverted back to 2.3 and kept it for awhile, but I guess now I will switch back.It also uses the capacitive buttons so it saves the wear and tear of the volume buttons and power button.
As follows:
Home button= Scroll up
Menu button= Scroll down
Arrow return button= Return to previous screen
Search button= Select
This makes so easy![]()
Edit: I knew back went back, but didn't realize I could use the other buttons too.
who flash on a regular basis, well........I don't feel like returning my phone or getting a new phone anytime soon
