I've just updated to 3.2rc2 & now my wifi wont turn on. Have been back into recovery & cleared cache & dalvik, but still the same.
Is there anything I should try next?
restore /system/lib/modules from the original romI'm on D4 Rom version 10
Cheers, but how would I go about doing that![]()
3.2 is up
(just cant get the staff these days ironass)
copy the rom
open the copy in 7zip
delete everything apart from META-INF and system
go into system
delete everything apart from lib
go into lib
delete everything apart from modules
save+exit
flash
your extweaks settings will be automatically reset after flashing this version
Has anyone else been having wifi issues (i.e. it refusing to turn on at all) with Siyah?
copy the rom
go into system
go into lib
save+exit
flash
Thanks for that ooberandy. I'm kinda relieved i'm not the only one having wifi issues with Siyah, although Hawker's solution seems sort of cumbersome to me (although kudos for figuring it out Hawker!). I might just stay away from it until a definitive fix is reported.I've been having some issues too. Hawker gave me the instructions shown above, but this didn't work for me. Might work for you though...
Ah thanks for that Hawker - I had been using an old version of you Blitzer script which was obviously causing all the problems. Cheers!The problem is not with the rom or kernel, it is due to kernel cleaners, hence the update to gs2wiper.
