Changelog:
As always, download here.
- new feature: “fix permissions in 2ndROM” in dual-boot menu
- new option: checkbox for “turn on the touchkey lights when the screen is touched” in ExTweaks
- you will have an error when trying to flash to 2ndROM before running ‘Wipe 2ndROM data/cache’ at least once. you need to create 2ndROM data and cache files in your sdcard first.
- set lulzactive default pump up/down steps depending on the frequency table step size. Default values will be initialized using the number of steps between 500MHz and 800MHz which is 3 with 18 steps.
- rebased lulzactive logic on new interactive governor
- new option: very simple CPU Undervolting in ExTweaks. -25, -50, -75, -100mV for all levels.
- progress bar for “Wipe 2ndROM data&cache” if it is performed for the first time.
- added adjustable mDNIe settings (thanks to sakura). you can use init.d script to modify the settings. the interface files are in /sys/devices/platform/samsung-pd.2/mdnie/mdnie/mdnie directory. echo 1 to user_mode and change “user_cb” and “user_cr”. default values are 128 and valid range is 0-255.
