JustSomeDude
I
Thanks for the advice - I'll definitely read up on that post before messing with kernels.
Another question: I've run across a lot of positive reviews of this VaelPak ROM. Any thoughts on that one in comparison to MikFroyo?
as ocn so correctly stated, the only way to truly find out is to give it a whirl. make a nandroid, wipe, flash and give it about 2 days after you get it within reason of how youd like it to be. if battery life isnt what you were expecting, there are kernel options you can try along with system governors and setcpu settings. ive read many positive reviews on vaelpak, but i have yet to try it either. but even if i did, again, my opinion of it might be different than yours. it seems as tho its an "everything works" type of rom, so id not be too gunshy of trying it if i wasnt so impressed with CM7.
