Wow, this was an easy install. Is there any way to have it set to only use for portrait and use the stock keyboard for landscape?
we'll see what happens after a few weeks of use though.what's the big deal with taking it down if its free.
It isn't "free". It was a restricted beta that was publicly leaked without permission. See post #131.
Doesn't insert a space after words even though I have that option selected in the Swype settings... think someone mentioned that before, any workaround/ideas? Thanks!
it does. Once you swype one word just start the next word and it will make the space.
Hmmm, am I missing a key that will drop the keyboard down like the default keyboard? Some websites that require a username and password will act like I hit "Login" if I use the return key after putting in my username without putting anything in for my password.
sniff, sniff.....WTF am I doin' wrong??? Downloaded, installed. Keyboard won't show up. When I pick Swype from "Text input", it selects it Ok, but NO keyboard. I even watched Tutorial....NOPE....goes through step by step, but Can't see keyboard.......WEIRD !!
Anyone?????????????????![]()
no, no...I did it right. But, they actual keyboard won't show. Even in tutorial, it goes through the steps "showing" how it works, but, NO keyboard to see.![]()
I still like it but I'm finding it might not be as useful as I first thought. I think my speed using it is about the same as the standard keyboard and it is a lot harder to use when driving I guess I'll probably switch back and forth depending on what I'm doing.
Did you follow all instructions I posted?
8. Disable Audio Warnings as it seems to give errors as well located at Phone settings -> Locale & text -> Swype
9.Reboot your phone. This seems to help in not having any FC's
