CyanogenMod 11 for the LG Optimus F3 (In a Beta-ish state!)
GSM (T-Mobile/MetroPCS) only at the moment.
CyanogenMod is a free, community built, aftermarket firmware distribution of Android, which is designed to increase performance and reliability over stock Android for your device.
Code:
#include
* Your warranty is now void.
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit Gerrit Code Review
Device Tree:
https://github.com/daemon32/android_lge_fx3t
Kernel:
https://github.com/daemon32/android_kernel_lge_fx3t
Instructions:
- Install aboot
- Root and install TWRP (here or here for aboot/fixed recovery)
- Flash with TWRP
- Clear data/cache/internal data
- Enjoy!
The rest of the pictures:
http://i.imgur.com/szXpCnR.png
http://i.imgur.com/KyO9Dzg.png
http://i.imgur.com/8r7pcYl.png
http://i.imgur.com/O3lB1eL.png
What works:
- Calls
- Wifi
- Data (3G/4G)
- Bluetooth (kind of)
- Sms / Text message
- Sound
- Rotation
- Microphone
- Speaker phone
- Headset/headphones
- Accelerometer
- Camera
Download Links
sha1sum: 435a6e692f9598fd58a9122e366dd2fdf0727427 cm-11-20150709-UNOFFICIAL-fx3t.zip
md5sum: 0d0408b7e5e5b322f1262730b9d6b9c9 cm-11-20150616-UNOFFICIAL-fx3t.zip
To xclusive36 for inspiration, and for some code
To hroark13 for the LG Optimus F6 KitKat device tree
