Root [T-Mobile/MetroPCS] [BETA] [4.4.4] Cyanogenmod 11 Unofficial
Well it looks like a soft boot, but whatever it is, is there a fix on my end that I can do to stop it? Like a setting or something like that? It's kinda annoying...lol
I just ordered some LG Optimus F3's for running some GPT apps. I'll be watching this thread for sure. I'm definitely rooting them but not sure if i should make the jump to 4.4.4 yet...
I just wanted to say
1. You guy are ****ing awesome! I never thought this day would come!
and
2. Is there a comprehensive list of what does and does not work yet?
and
The list is on the first post. It's not updated fully, but it should give you a rough understanding.
Yes those are the links but it send my to the play store to download a cloud app or something. I downloaded it, went back , tapped the link, said it started downloading but it never moved. It stayed at 0
My wifi is strong and work but the app mega doesnt want to download it
Could it be because of location? I live in wisconsin. Moved here 2 weeks ago
Can u test the links again? Or send me the rom through good drive somehow?
Google*
Are you able to try it from a computer?
Choose the "download through your browser" option.
Edit: your location would not matter.
And I've merged your sequential posts for easier reading;)
Do i download kk gaps aswell or do ot after flashing the rom?
You could download them now and put them on your storage, whether it be internal or external. Not familiar enough with the device to know;)
I also don't know what that whole "aboot" thing is in the OP, so you may want to wait until someone with more know-how than I to chime in here;)
Also, be sure to make a nandroid backup via TWRP before flashing.....it just may be your last resort in case something goes wonky:)
I used cwm. I download kk gaps then booted into recover, flashed cm 11 and gaps. It all worked great. The problem i see sofar is the torch doesnt work or the camera which i can do without. Thanks for your help. Can u let me know if updates will be coming oit to fix those problems
Yeah, that non-working camera seems to be a bug listed in the op :( But glad you got it working!!
No problem.
Well, you're on your own bud....as I stated, I don't have this device, nor am I on metropcs so I am not really following this.
Just check back every so often, don't ask the dev for updates, and just peruse through the thread to see other folks comments about bugs and such.
Good luck!
No problem.
Good luck!
Thanks
[Q
I have a tmobile version of this phone and every time i flash the aboot the phone goes into fastboot, the recovery does not open and the rom wont load without the aboot, so i was unable to use it. Could u give me clearer directions or upload a new aboot or a cwm recovery that works. Will there be a cm 12 with a lolipop rom? I need help to boot this, i had to reset my phone five times already.
OK so I was able to flash both twrp recoveries and both work. Also I was able to use the aboot after I made it into a flashable zip and flashed thru recovery. After I flashed the ROM and it finally worked, flashing the gapps also worked. It needs to be official and improved because the biggest issue for me is the storage swap. I can't get the external to be internal.
I have the same issue. External to internal doesnt work. I can learn to deal with it but i would like a futer update to solve these issuse. Im just glad to have kitkat on my f3
I just want to verify something: since you guys just flashed the rom, is LTE and Wifi working fine for you? I know camera and torch are the main issues, but are there are other issues so far?
I didn't know that using external SD as an internal was such a popular feature, I've been doing it since July on this rom... Maybe I'll put a new patch for it... ;)
(It's actually more involved than the normal external SD methods, but it is still quite simple)
Wifi should work, and I've only tested LTE for a few minutes, as I had to borrow a SIM card for it. Xclusive36 uses LTE on his, so in theory it's stable. As for the camera/torch, I wouldn't know exactly where to start, but when I have time I'll probably start working on it again.
Your the best
I went on the play store and downloaded some cm11 themes that seem to be work great. I have a question. Can i use freedom kernal to overclock to 1400hrz?Will it be safe with kitkat?
