I thought I read somewhere if you DON'T wipe cache and fix permissions when flashing the radio, it's likely to cause some issues later when using "force stop" command to close apps?
Jellybean 4.1.2 stock roms for Telus and Koodo added to the Odin guide.
My ICS Koodo phone is rooted, and using a T-Mobile radio (which I had to flash, in order to unlock my phone).
If I update to 4.1.2 my phone will
1. become unrooted
2. will lose the T-Mobile radio and revert to using a Koodo radio
Are both of these correct?
Hi.
In the instructions it says "If you are on 2.3.5: Superuser app 3.0.5 If you are on 2.3.6: Superuser app 3.0.7". I'm going to be getting the SGH-T989 which runs on ICS 4.0. Which superuser app version should I be getting?
Thank you!
Hi ipwnj00x :hello:
Congrats on your soon to be new phone!
Check this guide. It has more recent files. Also, the SGH-T989 was updated to Jellybean 4.1.2 a few months ago. As soon as you get your phone I would update to that if it isn't already. It runs better and is easier to root.
