Is there any way to fix the bootlooping after a factory rest?
From the OP
IF you want to do a factory reset. You need to flash step_1_f.zip again afterward OR you will get bootlooped
I honestly don't know what else I can say. You seem to be the only one reporting issues.
Sorry for the inconvenience but I seem to be out of ideas for the moment...
Thanks, but the wallpaper should have flashed too.I absolutely love this theme. Best one I have come across so far. I have a couple questions though. Where/how did you get the bee wallpaper because it didn't flash over with the theme and how did you get the stock dock thing back on the home screen? I followed all of the steps but I still have the go launcher ex dock at the bottom of the screen that came with shabbymod.
Anyway here it is http://img847.imageshack.us/img847/8372/defaultwallpaper.jpg
And the dock is not stock. It's called ADW launcher and there is a free version in the market
I am starting to get some force closures in the background... Ima try rc2 and let you know if they continue...
What version was giving you force close pop ups?
the first no ciq version
i think he said background FC's and if they were like mine there aren't any pop up windows, just the FC vibrations (one buzz shortly followed by 2-3 more) while doing other stuff
did you get any auto-reboots? (by the system)
if so that would be what mine was doing, though i don't remember what version i using at the timei got confused
maybe it was nociq RC 1??
