I would have to rebuild my framework over the no ciq base. Might do that later.
how do i get the launcher to work? i had a third party launcher and yours wont show up
im running it but mostly for test purposes i still like steel blue better
thought i should edit this to include blue this is a great job and for most that know me im not that excited about themes though blue has 2 themes so far i really like.
Steel Blue is a great looking theme , I hope he releases it soon.
On this theme .. I am not able to modify the power widgets , is anyone else seeing that or is it just me.
I was able to modify the widgets as usual...
Awesome theme Blue. I installed it last night and everything went smoothly.
I didn't have a problem editing the power widgets either. I did notice that my phone had a widget.txt.bak along with the widget.txt file. Are you sure you updated the right file dandnj1?
Hey Blue , awesome job man !!! I can't get over how responsive this theme is !![]()
Everything is checking out fine.. not one bug found... it would be cool if the status bar stayed transparent (grey) like in the step 1 zip though...
EDIT: Flashed the theme the second time... status bar was black... guess it was a anomaly the first time
