Root [THEME] Honeycomb Hybrid 3.0 No CIQ (Updated 10.19.11)
i got em, while using dropbox or checking my email, etc..
usually there would be 4-6 FC's (background) spread out over 30 mins to an hour then shortly after the phone would just reboot (without warning)
but nociq RC 2 doesn't seem be suffering from any of those side effects, just remember to wipe dalvik and cache part. before you flash and it should work out ok
i haven't had to factory reset yet *knock on wood*
Well the only explanation I can give is that the FC's may be due to the No CIQ components I missed in RC1.
I just updated my theme to Honeycomb_Hybrid_RC_2_NoCIQ3.1. Phone works fine and theme looks great. Great job Blue and thanks!
Thanks for this one, It really lays shabbymod out. I don't care for the boost logo on the pull down center. I would rather have seen your's and or shabbys' name/s'.
Sounds like I have a personal issue, I love this theme and what it does to shabbymod.
Great job and thank you for sharing.
To the rest, thank you for your own hard work doing this and your own projects as well ,
Thank you, hroark13, Interdpth, Shabbypenguin, Blooddawn, New Optimus, Obsession XYZ, and UOTK.
