brotherswing
Android Expert
My little gift back to the community, the Quicksilver theme for BACKside, Mate5, Quattrimus, Bumblebee, Cold as Ice, or the CM7 Theme Chooser. If requested, I will consider porting Quicksilver to any rom, as long as time permits.
QS has been updated for BACKside 00502 and Quattrimus Alpha 7, Bumblebee, and Cold as Ice Alpha9d.
Here are the screen shots (from the BACKside version).
To create this look, I used the icons from this ADW theme, Fancy Widgets with the Fancy Shadow skin by NYkrinDC. The wallpaper is Black Steel, and can be found here.
To get the best results for the status bar, make sure you have the status bar set to "theme" (for apk) or ROM (for zip) in >menu-settings-Cyanogenmod Settings-Interface-Status Bar Tweaks.
Note - Apk themes do not support bootanimations.
Mad props to Cammykool, who help me test this and gave valuable feedback.
As always I welcome your input and suggestions,
Download
Quicksilver BACKside 00502
Quicksilver Bumblebee
Quicksilver CM7
Quicksilver Mate5 1.1 (outdated)
Quicksilver Quattrimus Alpha 7
Quicksilver Kraven CM9 Alpha9d (Cold as Ice)
Download
Quicksilver CM7
ff
i hadn't expected that a theme would have to be re-heated for a ROM update
