I'll have a themed LP for you guyz tomorrow.
I'm a little drunk tonight.
Sent from my Droid using Tapatalk
Brutha, no worries
Wish I was feelin the spirits tonight as well
Upvote
0
I may have missed this in here completely, but is LauncherPro Beta no longer included?
Fab stated he would have one up as soon as he could.. But no, it's not included at the last one I had... Check up a few posts and you'll see he mentioned it (ie: couldn't find the quote to quote it for you here)
My market and gmail are broke with Froyo
The market will not show downloaded apps. No matter what I try, clear the cache, clear the market data nothing helps. I tried Titanium market link restore as well. Even when I download a new app it will not show up in downloaded apps.
My gmail will receive mail fine but will not send out mail. It just says sending... forever.
Did you try bghill's market fix? Leaked Version Froyo Market Fix - Team Chaos - AllDroid Public Board - Leaked Version Froyo Market Fix - Team Chaos - AllDroid Public Board - Forum
Mine was running slow last night for the first few hours after I first flashed the ROM, but it's settled in and is really fast now. I did run bgill's market fix update zip, and I also did a few battery pulls trying to find a kernel that would work for my picky Droid, and I've heard others report that each of those things have helped their market problems. All I know is that mine is blazing fast right now, and it sure wasn't last night.
Not sure if anyone mentioned this or not, but I just flashed the NexFro ROM and have the exact same wi-fi issue as NexBeast. I plan to try flashing the other FRF57 ROMs to see if the problem can be traced to the specific kernel rather than any modifications Fab or Pete may have done themselves...Flashed this morning with no install problems using ROM Manager. When I enable wi-fi, the phone continually scans although it does show a list of existing hotspots to choose from and I am able to select a hotspot and connect to it. Once "connected" the settings show a connection established, but the scanning continues and the 3G icon in notification bar remains.
Figure I'll try installing various other OC kernels to see if they help. If not, I suppose I'll go back to my previous FRFxx 2.2 install. Sigh.
Thanks for the great work nonetheless. I know it's only a matter of time. Besides, eventually a better version of 2.2 will drop and I'll be upgrading again anyway!
