Root TheUltimateDroid 3.2! :D
The_Chief
Accept no imitations!
Here you go!
Now the www.theultimateDroid.com
Happy flashing! :D
UD 3.2.0 Changelog
- Updated kernel for:
* Droid 1
* G2
* Evo
* myTouch 4g
* GTablet
* Nook Color
* Incredible
* Nexus S
- Updated proprietary files for:
* G2
* Evo
* myTouch 4g
* Incredible
- synced with AOSP
- clean up in builds of all phones
- updated googles apps
- updated market app
- updated all apps on the server
- saved even more space in system across all builds
- added 15 new awesome wallpapers to UD Wallpapers
- Many updates to the UD Launcher
* lots of code cleanup and fixes
* 7 screens
* four shortcuts in landscape
* configurable auto rotation
* double tap for previews
* configurable long-press on screen
* the ability to show and hide icon and shortcut titles
* full screen mode
- Updated Themes Menu in UD Extras
* 3 Official Ultimate Droid Theme (UD Nexus Red, Blue, Green)
* 20 theme chooser themes to choose
* graphical user interface
* Themer info
* Themer Donation links
* Twitter info
* submit your own themes
- added custom installs menu to the UD Extras Menu
- Added option to show/hide carrier label (Nihanth - UD Settings -> Status Bar Tweaks)
- Added option to show/hide scrollbar in notification power widget (Nihanth - UD Settings -> Notification Power Widget)
- added configurable AM/PM styles back into the status bar.
Includes Eclair's "Normal" style, Froyo's "Small" text, and Gingerbread's "None". (CEnnis - UD Settings -> Status Bar Tweaks)
- added "Default tab" setting to pick the tab opened when launching the Phone app (Paul Crovella)
- switched from GRI54 to GRI40 build ids for better market compatibility
- added fix for less sensor lag (rmcc)
- updated lockscreen arrow images (Sven Dawitz)
- non standard battery images in themes now handled better (Sven Dawitz)
- Better wi-fi connection for the Nook (Erik Hardesty)
- Fix slow video playback on the Nook (Erik Hardesty)
- added option for allowing purging of asset bitmaps (UD Settings - Pefromance - Pavel Kucera)
- fixed typo in APN list results in block mms for one of the providers (Sven Dawitz)
- added in some updates and fixes from CodeAurora
- fixed bootanimation graphical anomaly
- fixed gps lock on issue (Slayher)
- Added script to fix hot reboot
- added gmail and fancy weather widget to ud extras
- removed fancy weather widget from Droid 1 system
- changed default screen setup for Droid 1
- added all ringtones back to Droid 1
Well, don't feel alone... my Droid can't run Gingerbread. It wipes the tags off half my music, no matter WHAT ROM I tried. And I'm not going to add back tags to 419 songs just to run GB :eek:
Good luck...
glad im not the only one that has issues with music and gingerbread.
every GB rom ive tried removes all tags other than song title :(
Yep, still doesn't work. Works fine with UD froyo.
I think it's a prob with LP itself and that it's just not optimized for GB yet. Fede is rewriting the entire app, and that's probably something that'll be addressed when he's finally able to push that update. At least I'm hoping.
Me too and I hope so! My DrOID seems to really like gingerbread, but I don't keep a ton of music on my DrOID. My iPod handles that chore just fine. Haven't tried UD 3.2 yet but LGB 1.42 is rocking for me.
Anyone else run into the stupid status bar force closing problem yet?
And if so, is there anything to do to fix it, other than going back to 3.1.1?
Update:
For those who are encountering the force close bug with the status bar, just make sure you don't enable "am/pm" mode under the status bar options in the UD menu. Turning this off instantly and rebooting the phone fixed the problem for me.
Just in case anyone cares. :)
Good luck...
I was having this issue with my music running GB ROMs also. I have probably 760 songs in my D1.
Please note that my music is really organized (OCD I know! :p) artist,song titles, playlists and album art.
What I had to do was re-sync all of my music everytime I flashed a GB ROM... I'm using Doubletwist app with AirSync- it works perfectly (it doesnt take too long) :D
this might be a solution for you guys - I dont know.
Mine even does it on Froyo and on STOCK!!! I honestly don't know if I want another Android phone. As much as I HATE HATE HATE Apple...I need the songs on my phone to be tagged correctly.
What is everyone using to tag their music? I have a feeling that the issue is with your music files, not Gingerbread. I haven't encountered any issues with Gingerbread recognizing my music tags (Liquid, Ultimate Droid, Cyanogenmod music players all recognized my 3000+ song library).
Getting a lot of random reboots w/ this ROM whilst running GPS Nav. Off to try another flavor of GB.
3.2.5 was released today.
UD 3.2.5 Changelog
* Updated kernel for:
* Desire (CDMA/GSM)
* Evo
* Nexus One
- sync AOSP
- better battery life
- removed Bgill from the themer menu
- fixed a few issues with the ud launcher
- some modifications to bluetooth for greater stability and performance
- faster wimax connection for evo (cyanogen)
- cleaned up public API for Notification Profiles (martinlong)
- fixed issue with AM/PM statusbar configuration issues
- fix issue when capturing video from MMS intent
- fixing a race condition while stopping video playback (Vinay Kalia)
- fix repeatedly called onLongPress (fixes the camera app issue - Pavel Kucera)
- fixed typo in android that caused an connectivity issue (Kostya Dmitriev)
- egl: fixes for object refcounts (Michael I. Gold)
- some updates to the wimax code (rmmc)
- added mount/unmount/format options for removable mounts to Settings -> Storage (Cristian Henzel)
Well I tried it over the weekend and it seems that the magnet sensor is broken on this one. Didn't activate either the dock or the cardock. I know some people won't mind but I use the media and car dock all the time. Tried several reboots, but it didn't fix it. Back to 3.0.
I have two desk docks and two car docks, and 3.2.5 works fine in all of them. While the problem you're having may be software related, I don't think it has to do with the ROM itself.
Hmm must be just my phone. Oh well. Blackdroid will put out another release (if history proves anything) in about a month. Either way, I still love UD, by far best rom I've tried.
I tried using Copilot for the first time in a while this morning and got no audio. I tried Google Navigation and got a popup message telling me I had to download TTS data files. When I tapped OK I was redirected to the Market to install "SpeechSynthesis Data Installer" by "Android TextToSpeech". Suspicous of the publisher (not being Google), I proceeded to Settings > Voice input & output settings > Text-to-speech settings, where I found most of the options grayed out, but "Install voice data" was selectable. Tapping that brought me to the same Market link.
After doing a backup in ROM Manager, I re-flashed 3.2.5, wiping data and cache, and still had the same situation. I then tried re-flashing 3.2 and got the same results.
I'm sure this was working at some point with UD, but I'm pretty sure I started with Peter Alfonso's Gingerbread ROM, the flashed (without wiping) UD, starting with 3.0, then 3.1, 3.2, and finally 3.2.5. At some point in there I know TTS was working, but somewhere along the way these files disappeared.
I pretty sure it was UD 3.1 that claimed great space savings, when a lot of stock ringtones were missing, etc. Was removing TTS data a means of saving space in the ROM?
Regardless, I'm confused about what happened to my TTS data files that were previously working.
I don't know about 3.2 as I went from 3.0 to 3.3.0 and then 3.3.1, but I know blackdroid removed a lot of things to make more room. I had to go reinstall speach recognition and TTS in order to get them to work. I just flashed to 3.3.1 last night so I haven't tried tts or speach recognition yet but the mic is still on my on screen keyboard so it must still be there. I never did go to 3.2 as it didn't agree with my Droid for some reason but so far 3.3.1 is working good. Very snappy!!:D
Update: tried navigation, Yeah it's missing the speach file. I don't use the turn by turn so it doesn't bother me, I'll try downloading it tonight to see if I can get it to work and let you know.
