devilschild26
Android Expert
U don't need a PC only if ur coming from a recovery thats customAnd im not using a pc at all to do this??? Correct?? Bcuz i havent. This forum says no pc needed
Root means outside of folders with the rest of ur folders pretend the zip is a folder lol if in folder I don't ur gunna find the zipI just said it was on my SD card..i also made sure before the wipe/factory reset. So what do u mean keep it on the root of sd card. I must b really dumb.. wth guys lol
I just told u no u don't need a PC I've been doing this stuff for a long time listen to me and u will b rooted in no timeAnd im not using a pc at all to do this??? Correct?? Bcuz i havent. This forum says no pc needed
Ok what do i do with root master once i download it.Search key root master modded version its the top link download it
no PC do what hr said u b okAnd im not using a pc at all to do this??? Correct?? Bcuz i havent. This forum says no pc needed
Does root master have to be in a specific place on my sd card
No it does not its just an apk fileDoes root master have to be in a specific place on my sd card
Try againThat didnt work...it went thru a list of things then " update install aborted"
WHAT NOW??
Should i wipe data/factory resetTry again
U could if u want I never performed those actions are u on b07 or 6 could just be a bad DLShould i wipe data/factory reset
How do i find out?U could if u want I never performed those actions are u on b07 or 6 could just be a bad DL
Go into settings and about phoneHow do i find out?
Yup ur b07 then the zip suppose to work power off the phone take the batt out and try too flash again where u get ur phone atSays... SW versionN800.0.B07....thay right??
