yes when i clicked the button my phone restarted. so now what do i need to do?
Go here -> http://androidforums.com/threads/how-to-return-the-awe-back-to-stock.808228/#post-6336371
how do i revert to stock? all this is a hassel just to root...talk about " root of the problem" ha ha
ur awesome man..ill try this..when i revert am i going to lose all my apps/data/etc. ??
well i guess i should ask now will i be able to tether without carrier interference? this is one of the main reasons i want to root
gotcha..so before i revert do i need to backup my files..and will my sd card be untouched . or do i remove itIt worked for most everybody, I say that cause one person had to use a third party tether app but that's not that big of a deal
Yes backing up is needed but optional and ur SD card will be fine the way I did it was well I already had the zip placed on my SD card in new phone went into stock recovery and flashed zip over previous zip and it worked no back up and get a twrp zip and kitkat ROM very smooth built in tether and embedded superuser there's nine to choose fromgotcha..so before i revert do i need to backup my files..and will my sd card be untouched . or do i remove it
http://www.zteusa.com/media/wysiwyg/virgin-awe/update.zip download zip make sure its on SD card and u remember where its located flash zip in stock recovery then start again with root master
where is root mastser..isnt that chinese too? hahahttp://www.zteusa.com/media/wysiwyg/virgin-awe/update.zip download zip make sure its on SD card and u remember where its located flash zip in stock recovery then start again with root master
nice thx. but where do i get all this stuff..playstore never seems to have legitimate apps or files for the rootYes backing up is needed but optional and ur SD card will be fine the way I did it was well I already had the zip placed on my SD card in new phone went into stock recovery and flashed zip over previous zip and it worked no back up and get a twrp zip and kitkat ROM very smooth built in tether and embedded superuser there's nine to choose from
this stuff is so eazy look up key root master mod version its the first link dl it hit root then root again then hit betal reboot device ur rootedwhere is root mastser..isnt that chinese too? haha
Let me get u the linksnice thx. but where do i get all this stuff..playstore never seems to have legitimate apps or files for the root
so is rootmaster the same thing as RommasterSU file Curtis provided. damn i feel lost. smh
.so is rootmaster the same thing as RommasterSU file Curtis provided. damn i feel lost. smh
I never use play store black market I usenice thx. but where do i get all this stuff..playstore never seems to have legitimate apps or files for the root
noy yet, just making sure im asking all the questions i need to beyond revertingHey cj lord, do you have the Bo7 stock version?
so this is what i believe i need to do.
1.revert phone to stock
then following Curtis' steps
2. i would install Rootmaster
3.
