JollyRoger87
After a couple hours of trial and error, bootloops and force closes, I managed to trick the android market into seeing the triumph as an HTC Thunderbolt. I chose this phone as it has much more support than that of the triumph but also has very similar specs including the exact same chipset so most of anything you do decide to download in the market is likely to run just fine.
I started this project because I wanted to play gamelofts Order and Chaos Online. I downloaded a cracked version to see if the phone had the balls for such a game and to my surprise it ran perfectly. I myself am not one for piracy but I see no harm in a good experiment, So I emailed gameloft about adding support for our phones back in early August and never heard back. After playing with the Andro-Id rom I realized I had access to purchase the game and decided I'd come back to the stock rom and see if I could open up market access.
Flash this at your own risk and don't blame me if you screw something up.
For the stock ROM and it's variants
View attachment Vanilla_2.2_Thunderprop.zip
For Cyanogenmod 7 users
View attachment CM7_vB.08_Thunderprop.zip
For MIUI users
View attachment MIUI_1.11.25_Thunderprop.zip
For Ice Cream Sandwich users
View attachment CM9_0.5.1_Thunderprop.zip
Install Instructions
Step 1 Reboot into recovery and install your necessary version via clockwork recovery and reboot your phone
Step 2 Go to Manage Applications, click on market and make sure to force stop first and then clear data
Step 3 Enjoy
If you have any issues send me a pm with your issues, ROM you are using, version you installed (i know pretty self explanatory but things happen) and steps you took to install. I'll address your issues in the order in which they are received and do my best to fix it in a timely manner.
This has been tested with the purchase of Order and Chaos Online, Modern Comabt 2 and 3, GTA 3, N.O.V.A 2, ShadowGun, etc.
HULU plus can be downloaded however there seems to be a device check built into the App itself which denies us any playback - I'm currently looking into it
P.S. The EvDo mod that had previously been in the stock versions has been removed
Stock build.prop for the stock ROM and variants
View attachment Vanilla_2.2_Stock-Prop.zip
Stock Cyanogenmond 7 build.prop
View attachment CM7_vB.08_Stock-Prop.zip
Stock MIUI build.prop
View attachment MIUI_1.11.25_Stock-Prop.zip
Stock CM9 build.prop
View attachment CM9_0.5.1_Stock-Prop.zip
For those having issues with the android market recognizing their phones correctly or anyone wanting optimal compatibility with the gameloft games use this View attachment Gameloft_HD_Games_HTC_Thunderbolt_4G_android.apk with your stock browser to purchase gamelofts games made specifically for the Thunderbolt
Please note however, The Settlers HD has issues and is unplayable. Chainfire 3d "may" solve this but is untested
For MIUI users
Step 3 Enjoy
. I downloaded GT free hd.
