JollyRoger87
This was made to show the phone as a gingerbread thunder bolt. And I believe I used 2.3.4
Can you tell me which lines were changed, and to what? I just installed the "Tweaks" zip that is on here, and I would like to change this back so that I can access this stuff in the market again.
Thanks
I think you anyway I'll be looking forward to that.cm7 Has some bugs but what's working works fantastic. That I might have to go back to the other set up I had I'm so addicted to the game it's like world war craft. But i can be lazy in bed, playing the game.lol
Can you give me a little walk through how you installed it in order I'm dying to get this to work with cm 7 I've tried so many different ways to install it . thanks for any help truly appreciate itDownload it on stock then upgrade to cm7 and play, It worked for me that way.
thank you!op has been updated with a cm7 version.
I tried to flash the ThunderMod7.zip, but got error while phone was verifying update package saying that it was not signed and the verification had failed. What do I need to do to make this work?
I am running GSB V3.8 CyanogenMod7 on my phone
well ummmm duh that would be your problem.... this build.prop file is for the MOTOROLA TRIUMPH not the ERIS........Yes I have an Eris. Thanks for your help.
that would be why this part of the forums is aptly named triumph-all-things-root. "triumph" meaning motorola triumph....
I've tried to install the CM7 version a few times, it doesn't seem that anything has changed.. my baseband shows: M76XX-AAABQOLYM...
Model number: Triumph, Build number: GRJ90...
I've purchased OaC in the market, downloaded, but get the error that the phone isn't compatible
Work for the old version cm7 9/20 the new version 9/25 I haven't got it to work old version I use to have to install it get the game working uninstall it is there any new way to install it on the new version of cm7. Thanks for any help just love that order of chaos and will donate to you soon
