JollyRoger87
Can we install HTC apps on our phones now since its reading like its the thunderbolt?
Which apps were you referring to?
I feel there should be a clear subset of the changes that were necessary to "fool" the market. However, given that each change takes up to an hour to take effect, I don't know if I will ever be able to figure out the minimum changes required
How do you guys get the changes to take effect immediately? So far, all I can do is keep rebooting and check every 5 minutes...
I did revert back to stock prop and i was still able to play that i downloaded. I went to market to check if it changed back to stock in some way it did the gamelofts game are incompatible again but market still says virgin mobile htc would that stay that way even if im stock prop will it eventually show the triumph?
Help phone stuck in a boot loop! Please help....Wiped everything with clockwork as said in post now phone is in infinite boot loop doesnt even show virgin mobile symbol just shows motorola symbol then keeps saying "virgin mobile" then shuts off and repeats.
Nothing is reading on my Mobile F Drive it says "Folder Empty'....is it bricked?
Do you plan on making the build.prop work for CM7?
I didn't need to alter my build.prop any with Tickerguy's CM7 Tickerguy Edition v0.2 to see the gameloft apps mentioned...not sure about any of the others though.
I can also see them but when I try to play Order and Chaos it says my device is not compatible. I did not have that problem when I flashed the build.prop
Yeah.Did you download Order and Chaos with The thunder prop originally?
So is Order & Chaos any good?
