poler166
Did you install it via clockwork recovery?
Yeah I flashed it like a regular rom it flashed fine but when I have the game it saids it does not support my device
This is strange. Am I the only one? I don't need to use this anymore.
I'm seeing the same thing. Maybe they added support to our phone?
Edit: So I just bought the game without the build.prop and it says my devices is not compatible when I launch the game.
I'm on CM7, yes. 10/26 - vB.04 - Fresh flash and no issues, plays great!
--Even formatted /system before the flash.
So, I found some issues with this build.prop. I use a wired headset with a button on it that pauses/plays my music. It works fine with Slacker when I'm on the default build.prop, but when I'm on the thunderbolt one it sometimes doesn't work at all and when it does it pauses Slacker and then pushes play on the default music player.
Another issue I have is that I skip and rewind by holding down the volume keys when the screen is locked. Works fine on stock, doesn't work fine on the thunderbolt build prop.
How I found this out is that yesterday, all day, all of this worked fine. Then early this morning I did the thunderbolt build prop and suddenly it all failed. Then I came home just now and put it back to stock and now everything works again.
Info potentially important: I'm running the latest 11/06 tickerguy CM7 rom and also for my lock screen I use the latest Widgetlocker. I don't know if that last bit is useful, but it does have settings to enable to skip/rewind feature.
I'm running the latest cm7 and using B-randon's oc kernel..I just noticed after flashing thunderprop, it reverted my OS to 2.35, is this normal? Or does the thunderprop need to be updated?
anyway to make this usable for miui 11.25? I tried to flash the miui zip posted but it doesn't work
it doesn't work because it's not a flashable addon it's an extractable addon. extract the zip file and replace /system/build.prop with the file in the zip and then clear all market data and do a reboot. should work...
Actually that is incorrect, the Prop is made to be flashable to make life for everyone easier. It can however be extracted if you feel so inclined to do that extra work.
I will update the CM7 and MIUI props to their newest versions sometime today. I have things to do today but I promise the newest versions will be available today.
will there be any difference for CM7? I'm on the final build and it works for me, not sure if there is something wrong that I haven't noticed but in the market it shows my phone as "HTC ADR6400L" which is the thunderbolt.
nice i was waiting for an update![]()
Has anyone managed to get the stock thunder prop working with onlive app? i havent?![]()
Is the thunder bolt supported by on live?
