jbgremmels
I am running cm7 with no thnuderprop and onlive works just fine. I think thats due to cm7 being gingerbread.
yes the thunderbolt should be support because it's 2.3 that's the only requirement to get that app you think you can make a work around getting it onlive as I like being on stock and not being on miui or cynogenmod..
Hey everyone, I flashed Thunderprop for CM7 in the hopes that I would be able to get Age of Zombies to show up for me. I still can't get it in the regular Market or Amazon's Appstore. It shows up for me with my Nook Color (CM7) and my Evo3D (stock). Can anybody on here tell me if Age of Zombies shows up on your Triumph?
hey jollyroger. i was wondering if you could make a thunder.prop that works with brom v 1.0 running his kernel bkernel v .24? i flashed his kernel while on brom and then tried to flash the brom thunder.prop and it wouldnt boot. my phone kept getting stuck at splash screen. any ideas why?
yes I have that free Lego game but like I said is there a way to get this app to work on stock rather than miui or cynogenmod?
I have Stock 2.2 and I flashed it with Thunderprop, but I'm unable to purchase Hulu or Order & Chaos. I then tried adjusting the pixel density from 240 to 200, but no affect. My phone shows up as Model ADR6400L on both the phone and android market. I have restarted the phone several times and waited several days, but no affect. I get "This app is incompatible with your device", thus I'm unable to purchase it. I'd appreciate somebody's help. Thanks!
As in latest version of ThunderProp? Yes. And I haven't tried any previous versions, as I'm somewhat new to the Triumph.I just acquired it on googles 10 cent deal of the day with no problem. Are you using the latest version or was this attempted on a previous version?
Did you clear the market data?
I still am unable to see Age of Zombies. I'm totally confused right now. I've flashed back and forth between the stock prop and Thunderprop, rebooted, force closed and cleared market data, done all this repeatedly, even tried changing dpi settings, all to no avail. I'm beginning to consider reflashing CM7 and everything over again
EDIT: I just went to the web-based market on my PC, and when going to the Age of Zombies page it says "HTC ADR6400L This item is not compatible with your device"
Oddly enough, I am having no problem seeing Hulu+, O&C, and GTA3 as being compatible with mine.Hi JollyRoger, I'm new here and just flashed this .zip today but it seems as though I'm having the same problem as Cheechmo. There are no new apps available in the market to me, however when I look on the android market website it shows my device as Virgin Mobile HTC ADR6400L. It says that "this item is not compatible with your device" when I view Hulu plus, Order & Chaos, Grand Theft Auto III and Age of Zombies.
I'm on stock rom, this is and CWM are the only mods i've installed so far.
