TheBritton
Resident Galaxy Cat
this update was just to add ice cream sandwich support
Thank you!
I just downloaded the Thunderprop.zip for stock rom and opened and installed using cwr and when I boot my phone on,I still dont have full access to the android market.
My phone is still not recognized as the htc thunderbolt and I still cant play gameloft games like star front collision since Im a huge star craft fan.Not sure what the problem is but hopefully I can figure it out...![]()
Is start front even in the Android market?
Download the app in my first post and see what gameloft thinks your phone is. let me know what ya find out.
Why is it that I still can't play, Order & Chaos? It's like I downloaded the files but it won't even get to the menu and just crash and reboot. Any help?
Sent from my Triumph using Tapatalk
assuming you purchased it you should have no problems however it may be because of your ROM. Which are you running?
So seems like it may be the cm7 reloaded rom that's preventing this from working. If so, any ideas on a fix?
so you previously had it working? if so, on what rom? do you need the thunderprop? really sad because i bought this game and got my hopes only for it not to work
we should start a sticky of all the compatible games running different roms and what not.
I had it working on stock and the plain tickerguy cm7 releases using thunderprop. But I guess its the reloaded cm7 that's blocking thunderprop. I wanted to buy dead space and noticed I couldn't. But since I already owned all the gameloft games I guess I never noticed it was broken til now.
hmm i may try tg's any big differences between it and reloaded?
touchscreen sucks worse... Not updated graphics driver... Wifi and Bluetooth peg the cpu at max. Nothing too major, but it will be worse than reloaded since it hasn't been worked on in months...
so if you already own the games they will work regardless of whether you have thunderprop or not, is that right>?
Sorry if this has been answered but this isn't working for me in CM7 reloaded. Does it not work for this ROM or did I do something wrong?
