sharpe351
Should be assuming he made no major change to the build.prop
world fine on the current build. No problems at all
all i got to say thanks works perfect for me. only1 question is there a way to remove the adr6400l from phone model number and change to triumph in systems files some where. and still be able to download gameloft stuff with out problems thanks..
lol do you honestly spend so much time in your settings that it bothers you? I'm just playing but seriously I don't believe it's possible I've tried doing it with just the fingerprint and had no success.
The only disadvantage with this seems to be that it only works for me these damn phones can be so stubborn so now I'm running around trying to figure out why everyone is having problems. Although it seems my older versions were a bit more compatible for everyone so I'm going to make another set for everyone to try for those of you who cannot get this working. I changed to what we use now because of the quirky things it did to my phone (but apparently no one elses) like the back light staying on when in sleep.
Would you object to me posting an updated version of this mod for Whyzor's Reloaded rom? I made a custom version for me (with extra lines such as the EvDo only etc) but I also changed the MOD version in the file to reflect Whyzor's since the current ThunderProp still says TG Beta 8.. it flashes perfectly my first try at creating an updater script so I'm happy
Should Hulu work with this? I set this up but when I downloaded Hulu plus it still said the device was not supported. But looking through the thread is there another Hulu that does work?
links are broke on main page.
*edit* just weird in tapatalk. Links are in a strange place.
Why not just use the official phandroid app on this site?
What would be the point of this? for apps that don't support 4.0 yet?
For apps that will work on the Triumph, but are not specifically supported for it. Mostly video games and the like (but there are others).
i use tapatalk for everything.
I think it was just to add compatibility with CM9.Back on topic, what are the updates in this new build? I am still using the previous ThunderProp and wondering if it is necessary to update.
Thanks!
Same here. It's convenient to browse all of the forums with one app.
Also I notice Phandroid app remains in running processes even after killed. I'm sure it doesn't consume much memory but I'm obsessive about not being able to kill an app I'm not using for some reason
Thanks!
can i use this on the optimus v ???, i
