New Features:
* Based on Rom SAMMOD 007
* Added samsung apps
* Added TW Calculator
* Added TW Calendar
* Added TW File Explorer
* Added TW Messenging
* Added S3 lockscreen
*Added Samsung Keyboard
* And Many More
BUGS :
1. Messege not suport 2 sim, sms can send via only one SIM
2. Status bar FC sometimes when incoming calls ring And Many More....
Screen Shots: touchwiz_ROM.png
INSTALLATION GUIDE:
Place the ROM Zip file to your sd card (NOT IN ANY FOLDER!!!)
Switch off your phone.
Go to Clockwork mode.
Use the volume keys to move up and down.
Wipe data and cache and Dalvik cache.
Now choose: Install zip from sd card.
Choose ...........zip
Choose "yes"
It will be Installed. Now reboot your phone. First boot will take time. Be patient.
If you have followed EVERYTHING above carefully, you will soon boot up to your new rom.
Please wait until media scanning is completed.
Enjoy!!!
NB: to enable emotions symbol in messege go to messege setting and enable emotion...
ROM Download link: touchwizROM.zip
If above link not working then try this link: https://adf.ly/REjuZ
STATUS BAR FIX:
just flash above touchwiz rom...after boot in go to recovery again and then flash this :http://adf.ly/SgWuY
u can enjoy Samsung Galaxy S2 UI on A75... without any bug....
* Added TW Calendar
* And Many More
BUGS :
INSTALLATION GUIDE:
Choose "yes"
Enjoy!!!
STATUS BAR FIX:
