Root TouchWiz ROM (Samsung S3 ROM Ported for A75)
there is one more bug that I found ...somtimes music player & web browser closed automatically ....
ok i will upload complete bug free touchwiz rom .... i have solved all the problems in touchwiz.... :D and also made it fast.... i m using it from last three days without any problem...
Then upload it DOC as its one of the GOOD ROMs i have used so upload a complete Bug free ROM and haan please dont include the logo.bin with your image as to get it replace we have to flash the default logo file. Hay DOC one more request can you let us know how to make our own personal Logo.bin file.
Dude use RGB565Convertor to convert image in RGB565 then rename it to boot_logo & place it in system/media/image (replace the old file...) & reboot
thats it..
Except the statusbar issue everything is awesome.
no need to allow superuser tooooo for root needed apps.
And the launcher it is amazing with samsung swipe lockscreen.
TOTALLY NEW LOOK TO OUR DEVICE
ok ....and what about statusbar ....is there any solution...
Whats not working the status bar fix or the link as i have downloaded the status bar fix just now from the crossx A8T site so if its not working will wont replace it with the framework-res.apk of the ROM by the way did u tried to flash the fix as its not a flashable zip you have to manually replace the framework-res.apk of the ROM with the file in the fix. SO can u please let us know what u did.
the status bar fix not working
bro waiting for ur fix for statbar
i know that....woo ek behtarin ROM hoga...uske liye best of luck....... Waiting for rom
Rom ios ke baad ye 2nd (touchwiz) Rom hai jo mera favroute hai...aur is Rom me ek hi bug hai ...
......statusbar forse close.....
pls make a fix for it.....
ek fix jo maine mention kiya hi wo kabhi thik kaam karta hi khabhi nahi........
we r stil waiting.......
STATUS BAR FIX:
just flash above touchwiz rom...after boot in go to recovery again and then flash this :4shared.com - free file sharing and storage
u can enjoy Samsung Galaxy S2 UI on A75... without any bug.... :)
two bugs in this rom
1:- my phone will hang when i disconnect call
2:- my screen does not wake up during calls ..
plzz solve my problem ... becoz i want this rom becoz this rom is very very good system ui nd features ... sry for my bad english ... but plzz help me sir .......:(:(:(:confused::confused::confused::confused::D:D
I have used these updates with the Touchwiz Rebirth ROM by Gautam... It has changed the look of my statusbar and alongwith it we are able to do multitasking too... Thanks for it shrikant...
Try this multi locker app...... Flash this via recovery... I think it will work for sure..
It can be flashed in any rom.
Place apks in thier respective places if the zip is not flashed.
Press thanks button that saying thanks :)
