Root TouchWiz ROM (Samsung S3 ROM Ported for A75)
Simple method to flash framework-res.apk.
download the below attached txt file n rename it to reframe.sh with any filemanager n place it in sdcard (sdcard〉reframe.sh)
Place the framework-res.apk in sdcard〉.......apk
follow the steps:
open terminal emulator
type su
type cd sdcard
type sh reframe.sh
it will automatically reboots.
frmework-res.apk will be flashed.
HOPE IT HELPS TO FLASH FRAMEWORK-RES.APK MANUALLY
download the following zip n extract it to sdcard(sdcard〉reframe.sh)
http://dl.xda-developers.com/attach...18bfd2caf2c2/51d237fc/4/7/7/4/6/9/reframe.zip
follow the steps:
type su
type cd sdcard
type sh reframe.sh
download link not working.. says 410 - Gone
It is not flashable zip you need to extract the framework-res.apk file from the zip and then copy paste it in framework folder replacing the old framework-res.apk file and give permission as r-w-rr and then reboot. May be while replacing it you may get foreclose so you have to do it fast to avoid boot loops or else for a safer side have the aroma file manager downloaded by which in recovery you can copy replace any system file and give permission also.
this fix is not working..... i will give solution very soon.... n G
Good news I have solved Market and Browser search FC issue in JB V3 ROM.. :D download fix : https://adf.ly/RQBvD and flash via CWM Recovery :D
Password for file download from mediafire (if needed) : password.txt
status bar fix
until drdogautam solve the statusbar bug
try this fix...
but dont thanks to me....
Install using Cwm recovery
after boot change language to English
and u have done........
no prob. for me till now
status bar fix
try this fix...
it is status bar of JB v3 rom :D
bro waiting for ur fix for statbar
srry bro... i m working on hybrid ROM Now..... that will be a blast for MMX A75.... i m doing hard work on it ... and got success & made hybrid of LeWa + Stock A75 + Android 2.3.6 + Google Framework 2.3.7 ;)
as u have said in ur earliar post that u will give a solution give some time for this wonderful rom.....
i know that....woo ek behtarin ROM hoga...uske liye best of luck....... Waiting for rom
Rom ios ke baad ye 2nd (touchwiz) Rom hai jo mera favroute hai...aur is Rom me ek hi bug hai ...
......statusbar forse close.....
pls make a fix for it.....
ek fix jo maine mention kiya hi wo kabhi thik kaam karta hi khabhi nahi........
ok i will try to give solution.... once i completed hybrid...
