Root TouchWiz ROM (Samsung S3 ROM Ported for A75)
Please someone who is on this ROM not on TouchWiz Rebirth provide the screenshot of the Dailer.
I think nobody is on the Touchwiz... May be like me, must b on its rebirth version... Thanks to Gautam sir... Shahbaz, can u please tell me how should i get the beats manager get working on the Rebirth ROM??
Okay provide me the screenshot of the touchwix rebirth ROMs Dialer only.
I dint tried that.... A75 is not with me.
Ask @amolmendhe for help
OK then, i will give u the step by step procedure to install this ROM and get it work for u without any force close- 1. Goto Recovery mode,i.e CWM recovery mode 2. Wipe all things and do a factory reset. 3. Install touchwiz rebirth ROM of Gautam, not the previous touchwiz ROM. 4. Now Install the SuperSU ZIP file and after that Reboot the fone. 5. Now install chainfire supersu apk for getting the root permissions since the previously installed Super SU apk wont give u the root permissions. 6. build.prop file is for video recording, place it in system folder and give permissions as rw-r-r- . 7. Extract the files from systemui_touchwiz.zip and place in System/Lib/Hw and give permissions as rw-r-r- and reboot. 8. Now Final step is to again goto the recovery mode and install or systemui_tw.zip file so that you wont get any force close of status Bar. Thats it... Now Reboot and enjoy man... ;)
