Root uggh!!! Need help!!
Sorry it's taking so long bud if I could hold your phone it would be a diff story don't worry we will get you fixed up
If you do not, extract the one from the zip and paste it into system/bin. Change the permissions to read write execute, read execute, read execute, then reboot
it will let me copy, but it wont let me paste it off of my SD card & onto phone system bin folder
Need to mount system as read write. Astro should have this option somewhere in settings...if not es file explorer does and it's free
If you can mount system read write in astro you can just paste the file too...
I havent found any option that allows me to do this, any idea where?Im goin to bed, will check back in on this in the AM. feel free to reply before then with any suggesstions.
I really do appreciate the help you are offering.
Do you have busy box installed?
did you type su first
yes to both.
5677280234
9DFxBY
5677280234
so I should have a recovery.img file saved to root, check I should have flash image unzipped to a folder on my root, check. copy & save flash_image file to system>bin folder, check.
run emulator & type
watch flash_image, check
even did it watch <return> flash_image, and I get permission denied response.
