my phone is recognized on my computer I can download any file and place it on my card. That is how I placed unrevoked forevr and unrevoked forever son on my phone.
my phone will boot up after a battery pull. It stays stuck on the white screen in recovery. I placed the file on my sd root and booted up but it didnt do anything. I am ready to go back to my droid x and sell this rooted for cheap
that is what I am doing. but it says volume up to update the file volume down to not update. My volume up button is shot, does not work!ok so you need to rename the amon ra .zip file to PC36IMG.zip exactly. just delete the amon ra part of the file. make sure not to name it PC36IMG.zip.zip(as windows hides extensions). place that file onto the root of the sd card (not in any folder). then power off and press and hold power+vol down. it should scan it after that. hopefully that helps.
I saved it to the root as a .zip file, but again my volume up button is shot. so I tried something and unzipped on the pc and renamed the .img file & saved that to the root. No win!
I have my contacts saved to the phone because google is turned off. Way too many BS contacts in google that clog up my phone. I am restoring apps right now via Titanium, hoping I come to an option that allows me to restore contacts.
