Ok somehow i got to the recovery. Not too sure how or what i did different but im there. New problem everytime i got to flash the rom, i am using kaosfroyo v38, it says it cant open and then the file name and (bad).
So its Amon_RA recovery's flash option that's telling you its bad?
If so, it sounds like you might have an incomplete or corrupted download...
I've just downloaded the
kaosfroyo-v38.zip file from the Multiupload link in the dev's ROM thread over at XDA and here's the file size and MD5 checksum that I get (sorry, this took longer to download than I expected--blame Multiupload for the delay
File size:
75,271,487 (bytes)
MD5 checksum:
33a6cfb38740cd6f89fc91d21efd615d
You should double-check that you have the right file size and verify its MD5 checksum.
I just happen to know of an app that can help you...
...download
AFV (Android File Verifier)...its free in the Market.
Point it to your
/sdcard/kaosfroyo-v38.zip file, long-press the filename and select "MD5 Checksum" and see if the file's size and MD5 checksum match the above. If not, then you've got a wonky download and you'll have to re-download it.
If you've transferred it from your PC, then make sure that you do a "safe eject" before disconnecting the USB cable or closing the "disk drive" mount.
You could download it directly to your phone, but you should probably check the size and MD5 checksum then too (its always a good idea to check these--assuming that the dev has published his file sizes and MD5 sums, which is not the case in this instance).
Let me know what you find...
