Yeah well the app wont recognize root. The superuser
The reason this thread won't work out of the box is that erisuser1's Gscript scripts check that you are indeed using this method on an HTC Droid Eris phone (model "desirec") and the Kaos Froyo ROM does not support the getprop command/utility.
He said OneClick, not Dummies. AFAIK, jcase didn't use my scripts, did he?
No, jcase's app only cares about the phone being 2.1 and above...
>Yeah, I'm stupid...
I was reading thinking that he said this thread method wouldn't work... I was just editing my post when I saw your reply come in...
My advice was obviously silly given that...
<scary alien slinks back to his little green spaceship...>
Now, I'm just confused...and not sure what to have him try...
).Well, s/he says s/he has "kaosfroyo". (Hrm, any particular version, or all of them??).
Then s/he must be rooted. Sounds like the problem is just the WiFi tether app and some fog in the cockpit. No way to know, though if s/he doesn't use clear language.
Just to add to this, it's pretty well-known that the built-in Froyo Wireless tether does not work with any of the Eris Froyo ROMs. You need to run a third-party app for Wireless tether.
Thanks. I knew there was some reason that I was keeping that old .apk around.
Seriously, though: I have used the same one ("wireless_tether_2_0-pre10.apk") for a long time on both 2.1 and 2.2 ROMs (Kaos, Tazz, CELB) with no problems.
I haven't bothered to check whether the 2.0 release from that project works, but I bet it will, as the one I have been using was a pre-release candidate for the 2_0 version. (Only does AdHoc though, iirc).
eu1
Hey guys srry. I am in the military and I don't have alot of time but I am running koasfroyo v37and I have tried yalls support and I am believing I am rooted but the wireless tether you provided seems to not work either. I appreciate everrhing y'all are doing and I appreciate the support giving.I just need a wifi tether that will work. Tjs stuff is new to me. The error message I was talking about was when I ran this method it said I was not a Droid eris so that what got me all mixed up.
Ok. Thanks for the reply. It had to be an issue with the computer. I tried another computer and it worked. So I guess in all honesty the wifi apps gave me the impression that I was not rooted ans I got confused. So I thank each and everyone of you intelligent. Guys.OK, thanks for the clarification - now I understand what you meant a lot better.
So, scary alien's interpretation of what happened was correct - you got an error message about "not an Eris" because this rooting method is only intended to be used with "stock" HTC ROMs. As we have come to discover, you are already rooted and have a custom (rooted) ROM installed - KF v37.
As for the WiFi tether part, two things:
(1) I got the impression from your earlier post that what was happening was that when you were trying to start up the wireless tether app, you were seeing an error message from that app itself, claiming that it failed to acquire root - and this is what made you wonder if you had actually rooted. Is that correct? Also - since you apparently got a root prompt in the terminal window, by now you must have seen that Superuser pop-up window, and are familiar with the way it works, yes?
(2) Apparently you have tried installing a different version of WiFi tether, and you said "doesn't work". Unfortunately, "doesn't work" means little more than "failed for any reason out of a million" - did you get some sort of message about failing to get root permission, or did the app run, but the other piece of equipment fail to connect? Please be specific... and also note that the WiFi app I mentioned only supports Ad-hoc networking; some types of WiFi gear can not connect to Ad-hoc, but only WiFi routers in infrastructure mode.
eu1
brand new to this.........................
trying to root, but when trying to extract (fig. 12/13). nothing happens and it says "bad zip file." is there a new link for the gscript.zip?
another question is what's a good ROM right now. i know you suggest plainjane, but i figure that was like 6 months ago. Thanks!
.- Download gscript.zip (MD5 92796a8c6e61e8f1ee36e315c0acae7d)
My first suspicion is that you downloaded the file incorrectly, or you corrupted the file when you transferred it from your PC to the phone.
Note that the OP (original post) gave a "MD5 signature" for the downloaded file:
I should probably have also put a file length in there; the "gscript.zip" file is
3,915,189 bytes long.
Check your copy of the file (ON THE PHONE) - I am guessing it is shorter than this, possibly much shorter. If so, that indicates that the download got truncated somehow. You can use the Estrongs file manager to do this - long press on the "gscript.zip" file name, and select "properties".
If it is the wrong size, download it again. (There is also a free app in the marketplace by "scary alien" named "AFV Android File Verifier" - it will compute MD5 signatures for you if you want to check the file that way, and also display the file length.)
As for the ROM, try xtrSense 4.6.5 - that's a good starter ROM. Rock solid, everything "just works".
eu1
Can someone PLEASE help me? I followed the steps for the "Root for Dummies." Everything went through fine, until it was time to tap the "ROOT_PART2," it says permission denied! What am I doing wrong? Is there anyway I can just undo this ENTIRE process and get my phone back like normal?
-Thanks in advance!![]()
Scary alien, thanks sooooo much!!! I did do the phone reset, but the same thing kept happening. I tried deleting and re-adding the root 1 & 2 and i still got the same results. I guess i better leave it alone while i am ahead. Lol i'm too scared!
The other guys will chime in on the other problem but I personally like froshedyo v10. As far as the rooting goes you missed something. If you follow the steps EXACTLLY you shouldn't have any problems.
