I was following the instruction and just before I was about to flash the new ROM, I partitioned my SD card and now everything is screwed up.
Is there anyway I can start over from the beginning?
PLEASE HELP!
There are no instructions in the first three or four posts of this thread that instruct anyone to partition their SD card. So, I guess you mean "I was following the instructions, right up to the point where I decided to not follow the instructions."
When you say "just before I was about to flash the new ROM", do you mean that you had already performed the "wipe data/factory reset" procedure? If that is the case, it implies that:
1) You successfully got to the point where the Amon_RA recovery was installed and functioning. (That is good.)
2) The "wipe data/factory reset" means that your ROM is still bootable (but probably without the SD card in it), but it has been wiped clean, as in a new phone from the factory.
3) Partitioning of SD cards is destructive - so unless you backed up your SD card someplace, everything which was on it (pictures, music, etc) is now all gone - including the ROM file which you copied to the SD card AND THE NANDROID BACKUP which you made (if you were following the instructions)
Here is what I would suggest:
Unpartition your SD card and don't ever partition it again. Having a partitioned SD card merely interferes with your ability to jump back and forth between rooted Eclair ROMs and Froyo (or Gingerbread) ROMs.
You can unpartition your SD card with the menu in Amon_RA - just set the "ext" and "swap" sizes to zero, and it will reformat 100% of the card as a single partition.
Next, copy the ROM .zip file to your SD card - you can use the "Toggle USB-MS Mode" in Amon_RA to do this, or you can boot the phone and configure it minimally, so you are using the regular OS to do this same operation.
Then, boot into Amon_RA, and continue where you left off:
- wipe data/factory reset
- wipe cache
- flash your ROM.
eu1
