I have a rooted Eris with xtrSENSE. I keep getting the subject message popping-up, should I allow it to do the update or is that incompatible with the xtrSENSE ROM ?
Thank you so much! I had the hardest time finding a root method for my friend's HTC Eris since he missed the update and was stuck on 1.5. Many of the links out there today are expired and this guide was super easy to use!
awesome ive looked everywhere and tried many methods and this rooting from the phone seems to workout great....big thanks to all
So I have followed every step for this root and I still don't understand why it isn't working. I know that the thread is old, but I hope a few of you guys are still around, I really appreciate everyone who has posted here, thank you! My issue is tht when I reboot after running gscriptlites roots parts 1 and 2 I am unable to scroll to select back-up or flash a rom off of the sd card so I'm unable to actually root the phone... I'm mainly attempting to root this Eris so I can install an emulator for gba games, I have a thunderbolt running on cm and I just don't get why I can't scroll on the erisCongrats and Welcome to Android Forums. If have any questions just ask. There's still a couple of us that float around in here.![]()
Thank you , much appreciatedSome Eris handsets' tracball do not work at all, or strangely seem to not work only with the original Amon_RA recovery running.
You can follow doogald's advice above or you can simply get scary alien's tracball-optional recovery image and overwrite it to /sdcard/gscript/tools/recovery.img, and then re-run the rootimg part1 and part2 scripts. This does esentially the same thing as the original rooting method, but installs a tracball-optional variant of Amon_RA's recovery instead of the original Amon_RA recovery. (For all I know, that's the same instructions as "scenario three")
Good Luck
eu1
Thank you for the link to the other thread, and putting up the link for a working gscript.zipSo you are saying that you can start Amon_RA Recovery by starting the phone holding VolUp while starting the phone, but that the trackball is not scrolling the highlight in Amon_RA?
If that is the case, then you need Scary Alien's alternate recovery. See http://androidforums.com/eris-all-t...2-custom-recovery-trackball-not-required.html
Since you have GScript Lite installed already, Scenario 3 is your best bet.
Good luck!
Im a newb. I did everything you said and it works perfectly. However, I chose to use another rom, so I thought I had to repeat the rooting process. I had to download gscript and estrongs again on my phone because when I installed the new rom it didn't save the two, but when I tried to set up the gscript part1 and part2, it wouldn't let me. I figured, let me delete the gscript folder from the file manager and start fresh lol. I guess it doesn't matter because I already rooted it once before, but I want to ask you if my phone is still rooted and how can I fix this mistake?
Hi, I was wondering what size of micro sd card will I need to use to root my phone, I just ordered an Eris from Amazon but I want to order a micro sd card so I will have everything ready for when my phone arrives. Thank you
Thank you so much, I will probably get a 4 Gb card to start out with then.Does it matter if its micro SD or micro SDHC?I still have an 8 GB card in mine; that should be fine. It does depend on how often you want to back up your ROMs. If you don't need to back up a lot, 4 gb would be fine, too.
I need help with the rooting of my friends phone. She went and followed the steps listed on the first page of this thread with her eris that I gave her last month last night early this morning. She got all the way through wiping the phone in figure 39 and when she tried to load the XtrSense 5.0 rom to her phone but it wasn't there because I am guessing that she either unzipped it or placed in the wrong fold on the sd card. She only saw the two zip files Gscript.zip and rootme.zip. She tried restoring her phone in the recovery mode and got an error. She can still make calls with it and send and receive texts but all of her data and apps are gone. Can anyone on here help us with it?
Thanks
Patrick
Where is gscript.zip? When I google the filename every site I find that has something called "ilivid player" rather than a zip file containing the two root partitions described in your guide.
I just bought an Eris from a store on eBay, and it still has FW version 1.5 on it! I cannot believe the difficulties I am having upgrading and/or rooting my phone! I find dozens of "how to" guides, all of them stating I need to download specific files that are no longer available. For crying out loud, I can still download an MS DOS 2.0 bootdisk! Is Android some government program so secret that all references to are systematically deleted from the entire Internet? This is ridiculous!
..."the truth is out there"
[for you X-Files fans out there].Prerequisites:
- Eris w/ any HTC/VZW release (including 1.5, all leaks V1-V3, & root-ROM)
- Install free Market app Gscript Lite (PinkVenture)
- Install free Market app EStrongs File Explorer
- Download gscript.zip (MD5 92796a8c6e61e8f1ee36e315c0acae7d)
edit: please also reference this post http://androidforums.com/eris-all-things-root/127861-universal-eris-root-dummies-20.html#post3839877 for downloading the gscript.zip file; I've also updated the link (as of 8/27/2012) to have a new, alternate download link.
Thanks for that link, and thanks for not taking my rant personally. After two days for scouring the net, calling Verizon, and calling HTC, the closest I have come to getting my phone upgraded is having the HTC support guy say they'll do it if I sent it in ... with a check for $80! Yeah right! The reason I bought it was because it's cheap, not because I wanted to dump a bunch of $$ into it.
Now let me ask you this: as my phone is still v1.5, would it be better to root per the guide here, then pick some rom to flash, or would what these guys suggest be better as theirs is a 1.5 to rooted 2.1 method: [Walkthrough] From stock (1.5) to rooted 2.1 (update - new link) - xda-developers
