Thanks! This worked out and the update work but I still can't upgrade my android market. Any help?
Hey thank you so much for helping me but I can't seem to find the gingerbread software?
Hi folks,
I'm trying to follow this (27 page) thread and am getting confused as to what is the best current method and rom for my Eris. I rooted it years ago when I first got it (used) and it's running xtrsense but I only have a vague memory of that process and I'm not very tech savvy. In fact, I don't really follow Doogald's instructions above as some of it is over my head ("...Backup/Restore, then do a Nand backup of what you have now...") so I really need a dummies step by step guide.
Is there such a guide buried in this thread or is the guide on this page what I'm looking for?:
http://u-smartphone.blogspot.com/2013/04/update-htc-droid-eris-to-android-237.html
I have an SD card in the phone and can pull it and access it with the pc via a card reader but I don't seem to get to it when I usb the phone to the pc for some reason. (not sure if I need to be able to do that)
My goal is the Eris with a stable rom and 2.3 or better capabilities/speed. I like the small size of the Eris and don't want to upgrade to a newer (bigger) phone.
Thanks,
John
Hey John, welcome back!
I do see that you first posted in this very thread back on February 1, 2011:
http://androidforums.com/eris-all-t...ris-root-dummies-post2219671.html#post2219671
So, the first four posts of the this thread is the definitive "dummies" guide for rooting the Eris. It really does a great job of explaining all of the basic root concepts that one would normally use in rooting and ROMing your phone.
Is your device no longer rooted or do you just need a refresher on how to flash a ROM?
Let us know--there's still a few of us around for our beloved little Eris.
Cheers!
Yes, I hadn't realized that this was the same thread I'd used to first root 2.5 years ago! When I started to read it and saw the dates I assumed the information was probably obsolete.
I'm still rooted and running xtrasense. So as per my question long ago... I guess I just need to start with step 4 and use the link that Bob Cat provided below? (I'll have to read thru the steps again to see if I can follow them)
I now have a lot of apps on the phone. Am I likely to run into conflicts with the new ROM?
Also, an oddity... I got the email about the replies to this thread and clicking on the link originally opened the thread on the last page (27) but I left that page (for a reason I can't remember anymore) and could not get back to it. Whenever I clicked on pg 27 or "last" I would always be taken to pg 22. I even tried going to Bob Cat's profile and clicking on his recent post to get to the last page but no go. I tried erasing recent history (is that the same as cache?) but that didn't help. I finally had to open it in IE....
Yep, post #4 ("Finishing Up") is the right starting point for you and/or the second link that Bob Cat listed at the end (http://androidforums.com/eris-all-things-root/521699-flashing-roms-without-pc.html).
Yeah, I believe you'll have to re-install all of your apps if you're making a change to a different ROM. I'm not a big Titanium Backup user (great app, I just really don't use it), but you should be able to backup your apps on your current ROM with it and re-install them after flashing your new ROM. See this great FAQ thread here for more details:
http://androidforums.com/faqs/607141-guide-titaniumbackup-tutorial.html
Bob Cat or doogald might chime-in with better pointers about that, though.
Not sure about your thread/post navigation issues...might have just be a cache-confusion issue with this thread.
Cheers and best of luck!
Thanks. Reading thru the first threads, I realize I don't have the ES File Manager app on my phone. Is that only needed for the original root or will I need it for a new ROM too?
Just the original root...although it's a very handy app...I use it in-place of Astro File Manager (they bloated that app, unfortunately). ES File Manager is really nice and it also have a root browser mode that you can enable.
Well I tried to install Titanium and ES File Manager and google says they're installed but I'll be damned if I can find them on my phone. They don't show up under Manage Applications or any other applications list I'm aware of. They're not supposed to be something hidden in the background are they?
now another problem? I just got to the "choose update zip file" screen and there's only 3 zips showing...
celebFroyo4.3.zip
gscript.zip
xtrsense4.6.5zip
I had downloaded the new zip to my pc and then copied it to the sd card along side the other zips. Was that a mistake?
That looks like the problem. Downloading the plain zip file now.
So, do I need to go back to the beginning of step 4?
